How do i connect these fans properly?
Solved by Hairless Monkey Boy,
1 minute ago, JellyBurger676 said:Hi thanks for your reply.
So which connectors should I use? Only daisy chain and plug into rgb header? Will the fans get any power to spin or will this only be for the rgb?
You need to use both types on connectors. In your picture, the two on the left are female/male RGB, and the one on the right is for PWM fan control.
Featured Topics
Joseph_Stalin ·
Posted in General Discussion3 -
Evan37 ·
Posted in New Builds and Planning5 -
IlanMS ·
Posted in Peripherals9 -
Frossty ·
Posted in Graphics Cards9 -
StephenB95 ·
Posted in Displays4 -
5
Foxique ·
Posted in Networking2
