Hi! I've been planning to get an RX 570 for my PC, but upon inspection, I saw that my power supply (700 watts) has no 6-pin connectors (which I think the RX 570 uses) and it only has two 4-pin connectors.
Any ideas or solutions on what I should do to make it possible? Should I replace the power supply or not? Thanks. :)
https://linustechtips.com/topic/1232072-help-please/
im going to assume that's the eps connector.
also how crap is a 700w psu that is doesn't have a pcie connector, what unit?
Phone: Pixel 3a (Purple-ish).
Build Log:
https://linustechtips.com/topic/1232072-help-please/#findComment-13903261
can you share the model
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1232072-help-please/#findComment-13903262
Having no PCIe connectors on a supposed 700W PSU is quite an alarming sign. For an RX 570, I'd look at getting a new power supply. Do you have a set budget for it?
Desktop: Intel Core i9-9900K | ASUS Strix Z390-F | G.Skill Trident Z Neo 2x16GB 3200MHz CL14 | EVGA GeForce RTX 2070 SUPER XC Ultra | Corsair RM650x | Fractal Design Define R6
Laptop: 2018 Apple MacBook Pro 13"  --  i5-8259U | 8GB LPDDR3 | 512GB NVMe
Peripherals: Leopold FC660C w/ Topre Silent 45g | Logitech MX Master 3 & Razer Basilisk X HyperSpeed | HIFIMAN HE400se & iFi ZEN DAC | Audio-Technica AT2020USB+
Display: Gigabyte G34WQC
https://linustechtips.com/topic/1232072-help-please/#findComment-13903263
Any suggestions on what PSUs should I look for that isn't costly?
any set budget?
also what are you powering exactly?
also quote people so they can see your response.
Build Log:
https://linustechtips.com/topic/1232072-help-please/#findComment-13903284
Sorry, first time in forums.
it's all good.
An RX 570
PCPartPicker Part List
Type Item Price
Power Supply SeaSonic FOCUS 550 W 80+ Gold Certified Semi-modular ATX Power Supply $89.99 @ Best Buy
  Prices include shipping, taxes, rebates, and discounts
  Total $89.99
  Generated by PCPartPicker 2020-08-08 14:17 EDT-0400
Type Item Price
Power Supply be quiet! Pure Power 11 500 W 80+ Gold Certified ATX Power Supply $69.90 @ B&H
  Total $69.90
  Generated by PCPartPicker 2020-08-08 14:20 EDT-0400
to give some options.
Build Log:
https://linustechtips.com/topic/1232072-help-please/#findComment-13903307
Type Item Price
  Total $89.99
Pretty sure almost all PSUs at Best Buy are out of stock (just checked and it is OOS), but the Phanteks AMP 550w is $88 on Amazon but will take a week before shipping  @TechNewbie234
MAIN PC:
CPU: AMD Ryzen™ 7 7800X3D Motherboard: Gigabyte B650 Eagle AX CPU Cooler: EVGA CLC 240 GPU: EVGA RTX 3080 FTW3 Ultra RAM: TEAMGROUP Expert T-Create 32GB (2x16GB) 6000Mhz CL30
Case: CoolerMaster TD500 Mesh PSU: Thermaltake GF1 PE 750w Storage: 1TB Western Digital Blue 3D + 1TB Crucial P1 + 1TB ADATA XPG Gammix S11 Pro + 4TB Seagate Barracuda 5400RPM OS: Windows 10 Home
Headphones: Philips SHP9500s   Keyboard: Corsair K70 RGB MK.2 Cherry MX Red Displays: Gigabyte M27Q (27" 1440p 170hz IPS), Samsung UN32EH4003FXZA (32" 768p 60hz TV)
Former parts that I've used:  Intel® Core™ i3-9100F, Intel® Core™ i9-9900k, Asus Dual OC 2080, Gigabyte Aorus Master 3080, Gigabyte Gaming OC 3080, EVGA XC3 Ultra 3080, EVGA FTW3 Ultra 3080 Ti, EVGA 3060 XC, ASRock Z390 Phantom Gaming 4-CB, Gigabyte Z390 Aorus Pro Wifi, ADATA XPG 16GB (2x8GB) 2400Mhz CL16, Corsair Vengeance 32GB (4x8GB) 3000Mhz CL15, Scythe Fuma 2, Acer XG270HU.
https://linustechtips.com/topic/1232072-help-please/#findComment-13903341
