3 minutes ago, The Sloth said:
i5, due to higher IPC. Why not go for a Ryzen?
the 4790K has a pretty easy time outperforming the 9400F due to some pretty slow boost clocks. The single core boost is a mere 4.1GHz and the 4790K was made to overclock.
That said, there's a lot more that we need to know to answer this question.
@SnowyLynx-_- do you own one of these CPUs already? If not, what are the costs of getting both of these CPUs and motherboards? What kind of upgrade path is important to you.
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1231402-graphics-card-and-cpu/#findComment-13898020
this is the pc:    MSI GeForce GTX 1070 GAMING X GPU
Crucial MX500 500 GB SSD
G-Skill 4x4 GB Ripjaws X DDR3 2133 MHz RAM
Gigabyte Z97X-Gaming 5 ATX Motherboard
Noctua NH-D15 CPU Cooler
Fractal Design Define R5 Case (3 Fans)
EVGA 600 W1 80+ WHITE 600W PSU
Windows 10 Pro (Genuine and fully updated)
https://linustechtips.com/topic/1231402-graphics-card-and-cpu/#findComment-13898026
Don't think OP will OC, stock they are on par( at best, most of the time i5 will beat it due to IPC, it's also a newer platform so upgradability), keep in mind it's a old used pc, so expectations on OC will have to be managed, 5ghz is a pipe dream so 4.6 will be more realistic.
https://linustechtips.com/topic/1231402-graphics-card-and-cpu/#findComment-13898034
