Hello, I had my AMD Radeon 5700XT for a couple of months now, and I have been experiencing a bunch of weird issues.
Before anyone asks, yes, I did perform multiple DDUs and system reinstalls since I got the GPU.
My Radeon config also went through many iterations and, I probably did try all possible configurations.
First of all, the performance in many apps and games is lackluster, often falling below my old GTX 1060 3GB, and oddly enough, the performance often doesn't seem to be tied to the graphic settings.
For example, Rust, my framerate seems to be stable and nice, but it dips (and I mean it) and gets unstable if any players are nearby. My framerates are the same (plus-minus 3 FPS) in all settings, there is pretty much no difference between the lowest of the low, and ultra settings, if a player is nearby my framerate will dip to below 50/40 and sometimes below 30. A very similar issue is happening in Tower Unite.
Performance in Adobe After Effects is jokingly bad, Vegas Pro preview doesn't keep up even on the lowest quality settings, and Premiere is buggy when using the GPU accelerated mode.
Also, all modern emulation software like Cemu or Yuzu seems to work worse than on the GTX 1060, even when it's using Vulkan and not OpenCL.
The GPU also tends to hang my whole system and/or BSOD when I'm on Windows.
Oh and this one is nitpicky, but I can barely hear my GPU doing things, moving something in Blender or even drawing in Krita causes a very quiet buzzing sound that follows my cursor movement precisely.
Are all of those things typical for this card, or is something wrong on my end? Please help lads
https://linustechtips.com/topic/1229777-radeon-5700xt-issues/
The buzzing sound is probably coil whine. Its normal to an extent but I've never had a card do it badly.
As far as other issues, I'm not sure. Are you overclocking the card at all? I found RDR2 gets really stuttery if I OC my 5700xt past 2100mhz.
https://linustechtips.com/topic/1229777-radeon-5700xt-issues/#findComment-13884358
The coil whine is the least of my worries, and no, I didn't overclock the GPU at all.
https://linustechtips.com/topic/1229777-radeon-5700xt-issues/#findComment-13884364
Do you have any Radeon graphics settings trying to override game settings? What are temps like? Try running HWInfo and seeing if anything is getting really high utilization. Do you have an SSD game drive? What's your build?
https://linustechtips.com/topic/1229777-radeon-5700xt-issues/#findComment-13884376
Oh yeah, I forgot to mention. The usage is usually pretty low, IIRC my CPU usage was at around 30% and GPU usage at around 50/40% while playing Tower Unite with unlimited framerate. The same is true for other games.
My CPU is AMD Ryzen 7 2700X and I have 16 GB of RAM.
The drive also shouldn't be an issue, I'm usually using a M.2 SSD.
https://linustechtips.com/topic/1229777-radeon-5700xt-issues/#findComment-13884387
Are you on the latest driver?
Did you accidentally apply a power limit to the card some how either in Radeon software or MSI afterburner?
Intel Xeon 1650 V0 (4.4GHz @1.4V), ASRock X79 Extreme6, 32GB of HyperX 1866, Sapphire Nitro+ 5700XT, Silverstone Redline (black) RL05BB-W, Crucial MX500 500GB SSD, TeamGroup GX2 512GB SSD, WD AV-25 1TB 2.5" HDD with generic Chinese 120GB SSD as cache, x2 Seagate 2TB SSHD(RAID 0) with generic Chinese 240GB SSD as cache, SeaSonic Focus Plus Gold 850, x2 Acer H236HL, Acer V277U be quiet! Dark Rock Pro 4, Logitech K120, Tecknet "Gaming" mouse, Creative Inspire T2900, HyperX Cloud Flight Wireless headset, Windows 10 Pro 64 bit
https://linustechtips.com/topic/1229777-radeon-5700xt-issues/#findComment-13884900
All of those issues happen on both the latest stable and the beta driver, and no, I didn't apply a low power power profile/power limit. As I said, I did wipe my PC at least twice since I got the GPU, so settings like that wouldn't persist.
https://linustechtips.com/topic/1229777-radeon-5700xt-issues/#findComment-13884982
2 hours ago, Demonic Donut said:
Run HWInfo while gaming or running Furmark etc to get data while stressing the card.
Usually the issue you are having is driver or cooling related.
Here are my temps while running Tower Unite at highest settings with unlimited framerate
https://linustechtips.com/topic/1229777-radeon-5700xt-issues/#findComment-13886218
Try turning down the power limit slider in the Performance section. I typically run mine with a -15%, and it stabilizes many games that used to crash a lot. (I think my PSU is having issues with the power delivery, but I haven't checked for sure)
CPURyzen 7 5800X with Arctic Liquid Freezer II 120mm AIO & push-pull Arctic P12 PWM fans RAM: G.Skill Ripjaws V 4x8GB 3600 16-16-16-30
PSU: Be Quiet! Pure Power 12 M 1000W GPUASRock RX 5700 XT Reference with Eiswolf GPX-Pro 240 AIO & 2x Arctic P12 PWM fans Case: Antec P5
MotherboardASRock X570M Pro4 Monitor: ASUS ROG Strix XG32VC Storage: HP EX950 1TB NVMe, Mushkin Pilot-E 1TB NVMe, 2x Constellation ES 2TB in RAID1
https://hwbot.org/submission/4497882_btgbullseye_gpupi_v3.3___32b_radeon_rx_5700_xt_13min_37sec_848ms
https://linustechtips.com/topic/1229777-radeon-5700xt-issues/#findComment-13888403
