So what I would like to do is be able to use my nintendo switch and watch a youtube video on my computer and hear both audio sources through my one set of headphones. I am wondering if this is possible at all and if anyone can help me out. thank you very much.
System Specs
CPU: I7-5820k   MOBO:Asus X99 strix   RAM: 32gb corsair Dominator Platinum 2666mhz   GPU: Gigabyte G1 Gaming 980TI  PSU: Corsair RM1000i
https://pcpartpicker.com/list/mg7k2R
https://linustechtips.com/topic/1229409-combining-audio-sources/
I'm pretty sure you can get Y-cables for this
Main: AMD Ryzen 7 5800X3D, Nvidia GTX 1080 Ti, 16 GB 4400 MHz DDR4 Linux - Fedora
Wont that reduce audio quality though? I would like a way that doesnt just incase I do want to listen to music. But thankyou that might be the easiest way.
System Specs
Just buy a stereo extension cable, if the switch has stereo/headphones output.
Connect the cable to the Line In jack in the back of your computer, then click on the speaker icon / our sound card application by the clock and open the mixer and enable/unmute Line In
Stereo cable example : Amazon.com : stereo cable
