Budget (including currency): 750 USD
Country: USA
Games, programs or workloads that it will be used for: Gaming
First ever build. Looking for some advice and tweaking if needed.
https://linustechtips.com/topic/1229028-first-build-advice/
If you want to build now go with something like this, upgraded power supply and better graphics card. I would wait for the new stuff to come out though.
https://linustechtips.com/topic/1229028-first-build-advice/#findComment-13877993
8 minutes ago, BlueScope819 said:
whateverthefucknvidiawillcallthereplacementtothe1660super
2660 super?
please quote me or tag me @wall03 so i can see your response
motherboard buying guide      psu buying guide      pc building guide     privacy guide
ltt meme thread
folding at home stats
pc:
RAM: 16GB DDR4-3200 CL-16
CPU: AMD Ryzen 5 3600 @ 3.6GHz
SSD: 256GB SP
GPU: Radeon RX 570 8GB OC
OS: Windows 10
Status: Main PC
Cinebench R23 score: 9097 (multi) 1236 (single)
don't some things look better when they are lowercase?
-wall03
hello dark mode users
goodbye light mode users
https://linustechtips.com/topic/1229028-first-build-advice/#findComment-13877999
ltt meme thread
pc:
SSD: 256GB SP
OS: Windows 10
Status: Main PC
-wall03
https://linustechtips.com/topic/1229028-first-build-advice/#findComment-13878002
Similarly performing but cheaper motherboard, much better SSD, much better GPU, much better case for airflow and not to mention the worlds better PSU. The Thermaltake TR2 is an atrocity.
The "upgraded power supply" is just as bad, and the BX500 is DRAMless.
Also, waiting for new hardware for a $750 build is pointless as we're only getting high-end hardware at release (most likely 3070 and up for Ampere, for example). Mid and low-end components have pretty much always come at a later date.
Desktop: Intel Core i9-9900K | ASUS Strix Z390-F | G.Skill Trident Z Neo 2x16GB 3200MHz CL14 | EVGA GeForce RTX 2070 SUPER XC Ultra | Corsair RM650x | Fractal Design Define R6
Laptop: 2018 Apple MacBook Pro 13"  --  i5-8259U | 8GB LPDDR3 | 512GB NVMe
Peripherals: Leopold FC660C w/ Topre Silent 45g | Logitech MX Master 3 & Razer Basilisk X HyperSpeed | HIFIMAN HE400se & iFi ZEN DAC | Audio-Technica AT2020USB+
Display: Gigabyte G34WQC
https://linustechtips.com/topic/1229028-first-build-advice/#findComment-13878015
1 minute ago, BlueScope819 said:
No because it's the 2 prefix which means current gen RTX... probably 1760 or some shit because naming isn't a thing apparently *cough* i7-1065G7 *cough*
1560?
either way eventually 1060 2.0 or 11000.
to break up the second number....
1 (first number) 1 (second number) 0 (third number) 0 (forth number) 0 (fifth number)
first number is to keep confusion about RTX on 2000, so it will have to be kept.
second number and third number are the generation number, which starts and 6 and goes up in this case
last number is just another 0
ltt meme thread
pc:
SSD: 256GB SP
OS: Windows 10
Status: Main PC
-wall03
https://linustechtips.com/topic/1229028-first-build-advice/#findComment-13878017
1 hour ago, BlueScope819 said:
Agree with Darpyface here. I would recommend waiting two months for new cards to release a 3300x + a whateverthefucknvidiawillcallthereplacementtothe1660super would do nicely, or the whateverthefuckamdwillcallthereplacementtothe5600xt
Sure, you know, except for the fact those cards won't come out for a whiiiiiile.
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
https://linustechtips.com/topic/1229028-first-build-advice/#findComment-13878185
Just now, BlueScope819 said:
Sure, but even a paper launch would drive down prices for a 1660S
No, it doesn't. And they don't launch at the same time as the big boys, it's months after.
https://linustechtips.com/topic/1229028-first-build-advice/#findComment-13878217
9 minutes ago, BlueScope819 said:
Look at what happened with last gen.
You mean how the 1660 came out over 2 months after the 2060?
https://linustechtips.com/topic/1229028-first-build-advice/#findComment-13878271
4 minutes ago, BlueScope819 said:
No, I mean with GTX 10 series. They didn't launch the 1080 ti right away but the 1080 was the top line, and when they launched the 1080 ti you got lower prices on the 1080 and 1070 ti at shops.
Pretty sure that was probably more to line up with AMD than anything. NVidia stops producing GPU dies close to the end of the line, so there aren't any extra that need to be sold off for a cheaper price. Some retailers might drop them a bit, but most hold onto the price they're at.
https://linustechtips.com/topic/1229028-first-build-advice/#findComment-13878292
