Will PSU work
Go to solution Solved by Haro,
You only need the 8 pin eps. The other 4 pin isn't necessary and is only used for heavy overclocking. Which won't really happen with Ambient cooling. Plus the 8 pin eps can provide 384w of power easily. Which even a heavily overclocked 3950x won't reach.
Phone: Pixel 3a (Purple-ish).
Build Log:
https://linustechtips.com/topic/1228846-will-psu-work/#findComment-13876251
Okay, cause I have a 3900x cpu but I dont really plan on overclocking it, thanks
https://linustechtips.com/topic/1228846-will-psu-work/#findComment-13876257
