I've made my own etching PCBs in my garage. It's a simple circuit but the more fans the more complicated. I'm controlling 12 fans right now through software I made on the chip (ATmega 2560) in c++ and python on the computer it's just a serial connection through usb with a gui.
Mein Führer... I CAN WALK !!
https://linustechtips.com/topic/12281-pwm-fan-controller/#findComment-131502
Swiftech have an 8 way splitter that you might want to look into. Just plug it into the motherboard as well as a spare molex power connector and control 8 fans off one connector..
Hmm, it looks like a nice product and all, but I was thinking more of a sort of stand-alone controller. But if I'll have to make one myself, it might be a good place to start with butchering that one
Nice! My skills within these disciplines are a little limited, so programming-wise I didn't really imagine the possibility to tie in with the OS, and production-wise i might just end up using an avr Xplain board i have lying around (which, come to think of it, has USB on it). Maybe just un-split that swiftech splitter and tie it in with the whole setup as well.
I think some planning is in order!
https://linustechtips.com/topic/12281-pwm-fan-controller/#findComment-131713
I've building pcbs for about 2 years now that was one of my first more advanced projects but something on a perfboard is definitely doable for your skill set. Check out hackaday and instructables for some inspiration.
https://linustechtips.com/topic/12281-pwm-fan-controller/#findComment-133910
there kinda of a reason there are not many PWM fan controllers.
mostly under-volting them is terrible. linus' even commented
under-volting PWM is bad for the motor/circuitry. that the intention
of PWM was to let the PCB switching do the work and leave the voltage
input at static (12v). reducing the voltage develops un-needed heat and
reduces the relay performance.
buy 2-pin/3-pin fans and use a controller or allow a header to control PWM
using a swiftech fan block .
airdeano
https://linustechtips.com/topic/12281-pwm-fan-controller/#findComment-134618
just sayin.. it can be allot of fun to make your own ;P
My Meme Proudly Featured on the Live-Stream: http://prodigydoo.com/ImageStorage/memes/linus-meme-6.jpg
Some Threads You Should Get involved in: Linus and Slick Memes     Youtubers on the LTT Forum      The List of Tech YouTubers (Contribute!)      Disable AdBlock for Linus (Guide)
https://linustechtips.com/topic/12281-pwm-fan-controller/#findComment-134748
