Hello to all i need help and decide on what i will do thanks everyone who will help me out, first of all my pc is with this specs:
Ryzen 7 1700
Asus rog strix b350 f gaming
DDR4 Ram Trident Z RGB 16GB 3200MHZ (F4-3200C16D-16GTZR)
Asus dual gtx 1060 6gb
EVGA 550W B3
and all that i have it on a custom loop with bykski block, barrow pump , and alphacool radiator 240mm full copper.
Ryzen is OC to 3.9 but becuase i was having problems i take it back to stock.
So my problem is that before 1 year in b350 f gaming motherboard the 2 pwm ( cpu fan and cpu opt) stop working if you put a 120mm fan or 140mm fan but if you put the amd ryzen stock
cooler is working, and now before 1 week i take it all out to clean the computer and after put it back the motherboard doesn't recognise the second ram stick the manual says if you do dual channel put it 2 - 4 i try swap nothing i try to use only to the second with 1 ram stick and pc is booting i try and the other stick again is bootting but if you try to put and the 2 rams sticks is not working i take it to a computer technician and he tolds me the motherboards needs to be replaced so i will send it for Rma now the question is :
Should i sell the ryzen 7 1700 and the new motherboard from the rma and go for an i7 9700k and a msi z390 motherboard OR should i just buy an x470 or b450 msi of course what do you think ? ( and i will sell the new asus replaced motherboard ) i don't want to go again with asus i am dissapointed.
and something else the b350 f gaming doesn't run the ram to 3200mhz if i do an update i want it to 3200mhz as the ram is created for because i pay for that.
what you you think ?
thanks!
https://linustechtips.com/topic/1227211-help-me-please/
your ram is rated for 3200mhz, but your CPU might not be able to accept that
zen 1 architecture doesnt take anything past 3000mhz well afaik
-sigh- feeling like I'm being too negative lately
https://linustechtips.com/topic/1227211-help-me-please/#findComment-13862861
Why move to a dead platform?
No. Rma the board and wait for zen 3 and then decide which platform you want to move to. Don't even consider lga1151.
Either Zen 3 or heck even comet lake.
Phone: Pixel 3a (Purple-ish).
Build Log:
https://linustechtips.com/topic/1227211-help-me-please/#findComment-13862868
9 minutes ago, 5x5 said:
don't waste money on a 9700K. That's not an upgrade at all.
i wouldnt say 9700k isnt an upgrade for the 1700
but it sure is not one that makes sense, given today's choices
11 minutes ago, TofuHaroto said:
Either Zen 3
think he would need a new board for zen 3 because it's b350, which isnt supported right?
https://linustechtips.com/topic/1227211-help-me-please/#findComment-13862895
Well yes. But if OP wanted to upgrade either way. Coffee lake isn't really a good upgrade considering it's a dead platform.
Build Log:
https://linustechtips.com/topic/1227211-help-me-please/#findComment-13862903
just pointing out, in case OP wanted to just plop in zen 3 expecting it to work
https://linustechtips.com/topic/1227211-help-me-please/#findComment-13862906
Eeeeh, not really a real upgrade as you cut the thread count in half and triple the heat produced. The OP has a 1060 so gaming won't change at all with a 9700K
https://linustechtips.com/topic/1227211-help-me-please/#findComment-13863101
so zen 3 you mean the 3rd generation of ryzen ?? ( for example 3700x or maybe and 3600x is a good choice ) ??
https://linustechtips.com/topic/1227211-help-me-please/#findComment-13864438
what cpu you suggest me to take ?? and btw i want my ram to run at 3200 i don't want problems and what mb you think is a good choice ?? i want to plug it 1 time and not do something again i am tired to all that you know
https://linustechtips.com/topic/1227211-help-me-please/#findComment-13864444
11 hours ago, 5x5 said:
RMA the board but don't waste money on a 9700K. That's not an upgrade at all. Wait two months and get Zen 3. Also, be more careful when cleaning as you've probably damaged the board while handling it.
you mean 4000 ryzen ? ( this is the zen 3 right ? )
https://linustechtips.com/topic/1227211-help-me-please/#findComment-13864453
zen 3 is 4000. not released yet.
Build Log:
https://linustechtips.com/topic/1227211-help-me-please/#findComment-13864460
depends, are you looking to sell the system and grab something new or?
that's not a high priority thing to do, imo
sure, if your cpu supports it, zen 1 doesnt afaik
again, depends if you're keeping your current system or selling
im not too qualified to give MB suggestions anyways
no one likes when things go south, but it is a risk you take with any computers
https://linustechtips.com/topic/1227211-help-me-please/#findComment-13864463
Well, i want to sell the new motherboard from the RMA and of course the R7 1700 i will keep all the other things i don't care about the cost i give 250-300 euros for a motherboard i want to do OC and of course for CPU if you mean by 4000 series i will go with a R7 i want something good.
https://linustechtips.com/topic/1227211-help-me-please/#findComment-13864501
if you want 4000 series, you can make a new post after it releases, we'll help you pick a build then
https://linustechtips.com/topic/1227211-help-me-please/#findComment-13864523
I read that zen 3 will support x570 and b550 so it will not come new chipset ? it will be only x570 and b550 and with bios update it will support the zen 3 right ?
so what you think msi x570 ace or x570 aorus master ?
and second question
intel is used for years so you know that it will play right with amd is a risk to take it for example i take the R7 1700 and i am dissapointed
https://linustechtips.com/topic/1227211-help-me-please/#findComment-13864535
you think 9700k is not better choice ?? intel is used for years is something that you know it works i take risk to go with amd again as i did in the past and i am dissapointed.
https://linustechtips.com/topic/1227211-help-me-please/#findComment-13864548
depends, also consider b550. the ace is basically a unify with rgb. and yes you will have to move to a different board.
as for the master, afaik. it's overpriced and does not really do anything special.
yep.
Build Log:
https://linustechtips.com/topic/1227211-help-me-please/#findComment-13864549
yep.
x570 motherboard are better for OC right ?
https://linustechtips.com/topic/1227211-help-me-please/#findComment-13864573
nope, that depends on what b550 and what x570 board we're talking about.
Build Log:
https://linustechtips.com/topic/1227211-help-me-please/#findComment-13864584
not today, no
it's a decent CPU, but there's no future for that platform, it's dead
not worth investing
if you want intel, consider their 10th gen stuff, ie 10600k
not necessarily, it has to do with the connections u can make
x570 have more connections available, but also depends on individual boards to implement them
https://linustechtips.com/topic/1227211-help-me-please/#findComment-13864589
1 minute ago, Moonzy said:
not today, no
not worth investing
Okay thank you very much i will do a post when zen 3 comes out i will wait
https://linustechtips.com/topic/1227211-help-me-please/#findComment-13864605
