Cable Assitance
11 minutes ago, Pencil man48 said:I have a molex cable plugged into my power supply, but have no idea what to plug this cable into?
I also have to stray cables that i'm unsure what to connect these with. A "SATA" power cable and another cable of similar size, with a similar tip/ending to the SATA cable but it doesn't have a name or code that i can see on it.
You only need to use the cables your components require.
That probably means:
Motherboard: 24 pin and 8 pin
Videocard: depends. Could be no cable(s). could be a 6 pin, a 6+2 pin or a combination of either.
2.5" SSD/HDD/Optical drive: need a SATA cable
Other parts (like fan/rgb controllers, cases, etc.) may need power too, but that depends on what you have.
It's not uncommon to have a few 'leftover' plugs not used by any parts.
