your ram is running at 2133MHz effectively, but the true frequency is around 1067
because it's DDR (double data rate), where a signal is transmitted with both the rising and falling edge of a clock cycle.
thus effectively doubling it
though your ram is rated 2400MHz, so you might want to enable XMP/DOCP in the bios, or manually set it to 2400
-sigh- feeling like I'm being too negative lately
1 minute ago, Moonzy said:
image.png.4b0ca036b02d871b8e24a7a17a9b2760.pngimageproxy.php?img=&key=0c2a8b7d8afbc61a
Was it set to lower speed? Cause I didnt do it.
2133mhz is the default speed of the RAM
every ram when plug into a system runs at 2133mhz, unless specified otherwise
this is to ensure it works with your system, before the user changes the settings
Thanks. Now gotta go see how to enable that.
