Hi, i am not sure which AIO is best for todays high end cpus
I was looking at the
420 and 360mm Eisbaer series from Alphacool and looking at the Arctic liquid freezer series but i am not sure if there is better choices would love some help to figure out the best high end AIO for me
https://linustechtips.com/topic/1226611-help-picking-aio/
the arctic freezer 360mm is the ebst 360mm aio. but the 420mm aio will still beat it. get the 420mm aio. Whta are you cooling with this. Threadripper/10900k/gpu?
I Use my knowledge as business owner and self taught technician aswell as an AI to help people. AI might be controversial but it actually works pretty well 90% of the time.
https://linustechtips.com/topic/1226611-help-picking-aio/#findComment-13858360
Well the new EK 360 is solid too.
If you're willing to spend the 420 Eisbaer money then there's probably more cooling capability there though.
AMD Ryzen 5800XFractal Design S36 360 AIO w/6 Corsair SP120L fans  |  Asus Crosshair VII WiFi X470  |  G.SKILL TridentZ 4400CL19 2x8GB @ 3800MHz 14-14-14-14-30  |  EVGA 3080 FTW3 Hybrid  |  Samsung 970 EVO M.2 NVMe 500GB - Boot Drive  |  Samsung 850 EVO SSD 1TB - Game Drive  |  Seagate 1TB HDD - Media Drive  |  EVGA 650 G3 PSU | Thermaltake Core P3 Case
https://linustechtips.com/topic/1226611-help-picking-aio/#findComment-13858405
Yes Savage Neo i am building a 10900k system with a 2080 ti.
that i am trying to cool. there is space for any size cooler since i have a custom case made for it, to hide my computer away from my setup i don't really like having a big full tower or even midi tower standing in the room. so i made it into more of a hidden build that will be incorporated into the room itself and be hidden away, however i made sure to design plenty of airflow throughout it so it shouldn't run too hot.
https://linustechtips.com/topic/1226611-help-picking-aio/#findComment-13859092
12 hours ago, narrdarr said:
Your picks are probably the best. unless you want to spend about extra 120--150$ for an all copper aio like the Thermalright Turbo Right 360C
In my case this build isn't really price limited so that doesn't play to big of a role
https://linustechtips.com/topic/1226611-help-picking-aio/#findComment-13860302
just buy some thermaltake or something 420mm custom cooling kit
https://linustechtips.com/topic/1226611-help-picking-aio/#findComment-13860336
