First Triple monitor setup
lior1111
Yo guys! looking for a good brand for my first ever triple monitor setup stand , gonna put up triple 24'' monitors, what triple monitor stand are you all recommending?
Thank you!
I always go with VIVO, they make very reliable stands. https://www.amazon.com/dp/B078K23CFF
I've been using their STAND-V002F, STAND-V002, and STAND-MIC01 for a while now, excellent quality.
Make sure to quote me or use @PorkishPig to notify me that you replied!
Desktop
CPU - Ryzen 9 3900X | Cooler - Noctua NH-D15 | Motherboard - ASUS TUF X570-PLUS RAM - Corsair Vengeance LPX DDR4-3200 32GB Case - Meshify C
GPU - RTX 3080 FE PSU - Straight Power 11 850W Platinum Storage - 980 PRO 1TB, 960 EVO 500GB, S31 1TB, MX500 500GB | OS - Windows 11 Pro
Homelab
CPU - Core i5-11400 | Cooler - Noctua NH-U12S | Motherboard - ASRock Z590M-ITX RAM - G.Skill Ripjaws V DDR4-3600 32GB (2x16)  | Case - Node 304
PSU - EVGA B3 650W | Storage - 860 EVO 256GB, Sabrent Rocket 4.0 1TB, WD Red 4TB (x6 in RAIDZ1 w/ LSI 9207-8i) | OS - TrueNAS Scale (Debian)
I have Stell SOS 2030, its kinda pricey but its build like a tank and is excellent.
Has quick release tabs, supports up to 3x 32", you can adjust the position of each screen separately, even twist each screen as you like. Has excellent cable management and even USB and audio jacks (the cables could be black though and not colored).
However, I am not sure about availability where you live.
You can route cables under the black plastic covers under the arms.
IMG_20200124_083346.thumb.jpg.27c9f72286a6fb9fb70f903582d55291.jpgIMG_20200124_115526.thumb.jpg.8e31dd56002462344c54b9f77e1fc0f1.jpg
Thanks for your quick responses people! ill take a look :)
Can vouch for Steelcase. Expensive as shit but so good. I got mine for $10 used, was a lucky find. If you can find one, go for it.
Quote me to see my reply!
SPECS:
CPU: Ryzen 7 3700X Motherboard: MSI B450-A Pro Max RAM: 32GB I forget GPU: MSI Vega 56 Storage: 256GB NVMe boot, 512GB Samsung 850 Pro, 1TB WD Blue SSD, 1TB WD Blue HDD PSU: Inwin P85 850w Case: Fractal Design Define C Cooling: Stock for CPU, be quiet! case fans, Morpheus Vega w/ be quiet! Pure Wings 2 for GPU Monitor: 3x Thinkvision P24Q on a Steelcase Eyesite triple monitor stand Mouse: Logitech MX Master 3 Keyboard: Focus FK-9000 (heavily modded) Mousepad: Aliexpress cat special Headphones:  Sennheiser HD598SE and Sony Linkbuds
