GPU Upgrade - Need help
By
JayBe
in Graphics Cards
in Graphics Cards
Solved by Oswin,
Just now, JayBe said:Yep, exactly.
True that.
Thanks to both of you
In case i won't be able to afford one of the 30 series. Would you rather recommend the 2070 super or the 2080 super?
the 2080s will give you a better experience if you can afford it, especially at 1440p.
derekchan ·
Posted in New Builds and Planning4 -
5
1
5
kerriya ·
Posted in Cases and Mods9 -
octester ·
Posted in Troubleshooting7 -
DavidPatrascu ·
Posted in General Discussion9
play_circle_filled
Latest From ShortCircuit:
