This is my first time posting here.
Im going to be  a first time gaming pc builder but still lack some of the knowledge needed. I want to build a mid range pc with second hand parts hopefully around £750. I currently am set on an i7 3770k, an nvidia gtx 1650, a 1tb ssd, 16gbs of ram. Could anyone advise on any good motherboards, PSUs and cooling systems that would suit the current parts I need. Also any other advice for a first timer would also be much appreciated.
https://linustechtips.com/topic/1225978-advice-needed-for-first-time-pc-builder/
reason for not going amd?
i would suggest an 80+ gold psu from a reputable company like corsair or be quiet
for cooling i would advise noctua or be quiet
PC specs:
Ryzen 9 3900X overclocked to 4.3-4.4 GHz
Corsair H100i platinum
32 GB Trident Z RGB 3200 MHz 14-14-14-34
RTX 2060
MSI MPG X570 Gaming Edge wifi
NZXT H510
Samsung 860 EVO 500GB
2 TB WD hard drive
Corsair RM 750 Watt
ASUS ROG PG248Q
Razer Ornata Chroma
Razer Firefly
Razer Deathadder 2013
Logitech G935 Wireless
9 minutes ago, Sorenson said:
This is a night and day better build.
CPU: AMD Ryzen 9 9950X3D · Cooler: Noctua NH-D15S Chromax.black · Motherboard: Gigabyte Auros X670 Elite AX · RAM: G.Skill Flare X5 64GB (2 x 32GB) DDR5 6000MHz CL30 · Graphics Card: Zotac NVIDIA GeForce RTX 4070 Super Twin Edge OC 12GB · Boot Drive: 1TB XPG Gammix S70 Blade NVMe SSD · Game Drive: 2TB WD SN850X NVMe SSD · PSU: Seasonic Focus GX V3 1000W 80+ Gold · Case: Fractal Design North Mesh · Monitor: MSI Optix MAG342CQR 34” UWQHD 3440x1440 144Hz · Keyboard: EPOMAKER x Aula F99 Wireless Mechanical Keyboard · Mouse: Logitech G309 Lightspeed Wireless Gaming Mouse
what working parts do you have on hand?
target monitor  resolution?
tip 1 dont pick top / bottom of the line, pick second best
Well I have no working parts as I want a fully realised plan before spending any money and I was just hoping for something mid ranged that could comfortably run games at 1080 60fps
On 7/23/2020 at 10:57 PM, Sorenson said:
This sounds great. But will I need a case fan or WiFi card as well?
On 7/23/2020 at 11:57 PM, Sorenson said:
750w????? Is there a 3950x with 2x 2080ti in SLI that i overlooked 😂
Why such total overkill psu for this max 250w system? It could do with any decent 450w unit and then still have a ton of room to spare... (although id go 550w as most quality units start in abt that range).
Note it might be a good choice if prices are out of whack locally wich sometimes happens. But i suspect op can save a good few quid not looking at 750w units.
I was looking at a Corsair 450 watt for £40 anyway
After looking at posts here i see it is cheaper and better to pick amd Ryzen 3 3100. Thanks for the PSU advice as I have picked a Corsair 450w option.
what corsair psu?
On 7/23/2020 at 2:57 PM, Sorenson said:
ou're better off just going new and not buying overpriced used hardware:
what?
a pro max (non m) is generally cheaper and does the same thing.
get an actual good case. and you dont need a 750w.
Phone: Pixel 3a (Purple-ish).
Build Log:
If the ryzen 3 3300x is not that much more expensive and if you can find it I would go for that one instead and if you have some money left you could get a gtx 1660 super or something along those lines.
I9 10850K
EVGA RTX 3080 TI FTW3 ULTRA
32 Gb Crucial Balistix ddr4 3600mHz 16-18-18-38
MSI Z490 Tomahawk
Fractal Design Ion+ 860W platinum
Arctic Liquid Freezer II, 360mm
WB Black SN750 NVMe ssd
TeamGroup L5 3D Lite 1 Tb sata SSD
It was the cheapest option that was good quality. It’s a decent quality psu that’s around 100 euros.
3 hours ago, shadowfaj said:
Thanks for all the help everyone. After revising my ideas, I came to a much better plan which costs me £567. I will attach a photo of my parts list and I can't wait to share the finished product with you all once completed.
This is almost a really good build. I would go with the 1650 super though. It is a way better option and only costs like $10ish more.
A CX? System Power 9? Don’t think you need a Platinum 750w psu for an average build.
how about you link PSUs that are available in his market that are better instead of just listing off random PSU brands that could be out of stock. I listed the best one IMO that was available at an affordable price at the time of posting.
3 minutes ago, Sorenson said:
brands
These are models.
PCPartPicker Part List
Type Item Price
Power Supply Corsair CX (2017) 550 W 80+ Bronze Certified ATX Power Supply £74.98 @ Amazon UK
  Prices include shipping, taxes, rebates, and discounts
  Total £74.98
  Generated by PCPartPicker 2020-07-26 07:39 BST+0100
Type Item Price
Power Supply be quiet! System Power 9 500 W 80+ Bronze Certified ATX Power Supply £54.92 @ CCL Computers
  Total £54.92
  Generated by PCPartPicker 2020-07-26 07:40 BST+0100
Type Item Price
Power Supply Corsair CX (2017) 450 W 80+ Bronze Certified ATX Power Supply £54.99 @ Amazon UK
  Total £54.99
Edited by TofuHaroto
Build Log:
