I'm gonna try and make a Virtual Machine, so me and my brother can play on the same computer at the time, but I have a ryzen 5 3600X 16gb of 3200 and 2060S would that be enough to make a virtual computer and have enough memory for both of us? Would i have to get more memory? Also I have a old 980ti, could I put that into the computer have him use that for the Virtual Machine, while I use the 2060S.
Edited by Goku1814
https://linustechtips.com/topic/1225515-need-some-help/
i mean it wont be the best, assuming both get equal resources, it'll be 3v cores and 8 gigs per user, if you want you can try it out and check.
10 hours ago, Goku1814 said:
2060S
edit, one gpu wont work for more than one vm.
Edited by TofuHaroto
Phone: Pixel 3a (Purple-ish).
Build Log:
https://linustechtips.com/topic/1225515-need-some-help/#findComment-13849110
1 minute ago, Goku1814 said:
I have a old 980ti could the Virtual Machine use that while i use the 2060S?
what games r u looking to play, if u split it into 2 you'll only have 3 cores each
assuming a third isnt needed to supervise both VMs
that's not a lot of cpu power to go around
but yes it can work
-sigh- feeling like I'm being too negative lately
https://linustechtips.com/topic/1225515-need-some-help/#findComment-13849124
So I would have 6 cores for me and 6 cores for him?
SMT is not cores. having 6 hyper threaded cores does not equate to 12 cores.
Build Log:
https://linustechtips.com/topic/1225515-need-some-help/#findComment-13849134
Ohhh okay I understand but if I were to plug in my old 980ti could I get Minecraft to run off of that and get fallout 4 to run off of my 2060S?
Edited by Goku1814
https://linustechtips.com/topic/1225515-need-some-help/#findComment-13849146
if  you allocate that certain gpu to that certain vm then yes.
Build Log:
https://linustechtips.com/topic/1225515-need-some-help/#findComment-13849149
