Enough water flow in loop
Solved by RollinLower,
3 minutes ago, BlueScope819 said:What are your specs? 3 420mm rads? No CPU and GPU combo on earth would need to be cooled by that much
it's overkill, but i'd say there's still some sense in going overkill now.
-future expansion options without altering the loop
-super low temps
-super high clocks
-ultra low noise
7 minutes ago, Peanutshock said:Hello, I’m going to be build my first custom water loop and I was wondering if one D5 pump would have enough pressure for 3 420mm radiators, a cpu block and a gpu block. I’m going to be building in the TT View 71. Thank you.
a single D5 would be enough i'd say. it also depends on how restrictive (read: how much bends) is in your tubing.
