Budget (including currency): £1400
Country: United Kingdom (England)
Games, programs or workloads that it will be used for: Gaming (Most likely Minecraft), Streaming, Video Editing, Work.
Other details: Only need 1 Monitor, don’t really need High refresh rate. 1080p will be fine. Don’t need any other peripherals. Need OS = Windows. Would be nice if it had a bit of RGB action. Upgrading from an old Intel i3 Laptop that can barely run anything.
I have done a quite a bit of research but thought I should come here for a final check to make sure my original part list is ok.
Parts list: https://uk.pcpartpicker.com/list/vCXMWb
Please could you reply with advice, Thanks
https://linustechtips.com/topic/1225432-first-gamingstreaming-rig-need-advice/
please quote me or tag me @wall03 so i can see your response
motherboard buying guide      psu buying guide      pc building guide     privacy guide
ltt meme thread
folding at home stats
pc:
RAM: 16GB DDR4-3200 CL-16
CPU: AMD Ryzen 5 3600 @ 3.6GHz
SSD: 256GB SP
GPU: Radeon RX 570 8GB OC
OS: Windows 10
Status: Main PC
Cinebench R23 score: 9097 (multi) 1236 (single)
don't some things look better when they are lowercase?
-wall03
hello dark mode users
goodbye light mode users
5 minutes ago, wall03 said:
bad mobo, can't really run a 3700x
OP only plays mincraft though
shit case with no airflow
Corsair CXM 650 W 80+ Bronze Certified Semi-modular ATX Power Supply
low tier PSU for such a high end PC.
1. instead of overpaying 100+ for windows, you could get an OEM key for 15$ or so.
2. with ryzen, you dont need an aftermarket cooler to begin, the stock cooler will work well. use the money saved from os and fan cooler into a better gpu.
3. get a larger nvme ssd instead of the sata one youve gone for.
4. get a RMx PSU instead of the RM.
6. you could cut costs by going with a 3600 instead of the x variant
5. ive heard the gaming edge runs into issues pretty often, consider another motherboard, though im not sure.
do you urgently need this pc? coz if you dont, you should wait. by mid-september, new ryzen cpus (4000 series) and nvidia gpus (3000 series) are coming out. you could get more performance for the same price youre paying now. i myself am waiting to build my gaming rig. its gonna be worth the wait.
if you do urgently need one, heres a list
ltt meme thread
pc:
SSD: 256GB SP
OS: Windows 10
Status: Main PC
-wall03
G502 Lightspeed Review
PC:
i5-6400
GIGABYTE GA-H110M-DS2
CORSAIR VENGEANCE LPX 2X4 DDR4-2666MHz
ASUS ROG STRIX-GTX 1060-O6G
SEAGATE 2TB HDD
FUJISTU F300 240GB SSD
CORSAIR CX750M
Laptop:
Acer Nitro 5
i5 8300h
GTX 1050 4Gb
12 Gb RAM
128 Gb SSD
1 Tb HDD
Peripherals:
Keyboard:
Logitech G310 Atlas Dawn (Romer G)
Rexus Legionare MX5.1 (Content Browns)
Mice:
Logitech G602
Logitech G502 Lightspeed
Steelseries Rival 105
Logitech M330
Headset:
Logitech G430
Cooler Master MH 752
Went with the 3700X as you mention video editing.
Assuming you want/need wifi.
Swap the SSD to a smaller one if you don't need 1TB.
If you want a bit extra gpu power then go with a 5600XT. The 1660 Super is fine for 1080p though.
Case is personal pref, but the Aerocool is good value as you get 4 ARGB fans included for just over £50.
PCPartPicker Part List
CPU: AMD Ryzen 7 3700X 3.6 GHz 8-Core Processor  (£250.56 @ Amazon UK)
CPU Cooler: ARCTIC Freezer 34 eSports CPU Cooler  (£29.99 @ Amazon UK)
Motherboard: MSI MAG B550M MORTAR WIFI Micro ATX AM4 Motherboard  (£169.98 @ Amazon UK)
Memory: Kingston HyperX Fury RGB 16 GB (2 x 8 GB) DDR4-3200 CL16 Memory  (£74.99 @ CCL Computers)
Storage: ADATA XPG SX8200 Pro 1 TB M.2-2280 NVME Solid State Drive  (£129.99 @ CCL Computers)
Storage: Western Digital Blue 2 TB 3.5" 5400RPM Internal Hard Drive  (£55.22 @ Amazon UK)
Video Card: Gigabyte GeForce GTX 1660 SUPER 6 GB OC Video Card  (£208.98 @ CCL Computers)
Case: Aerocool Aero One Eclipse ATX Mid Tower Case  (£53.99 @ Amazon UK)
Power Supply: Corsair TXM Gold 550 W 80+ Gold Certified Semi-modular ATX Power Supply  (£69.99 @ Currys PC World)
Monitor: LG 24MK600M-B 24.0" 1920x1080 75 Hz Monitor  (£112.89 @ BT Shop)
Total: £1156.58
Generated by PCPartPicker 2020-07-22 15:04 BST+0100
