i have an old pc ,i5-4670k gtx 760
worked just fine, i did an driver update and its not working properly anymore.
i see my gpu in device manager (error code 43), i downgraded my driver multiple, but nothing, at first my pc didnt boot i had to boot without driver signature enforcement to unistall my drivers.
I have display from my gpu ( hdmi plug in gpu) fan works
please help
https://linustechtips.com/topic/1225164-pc-detect-gpu-but-it-does-not-work/
Ddu ( display driver uninstaller) the drivers and then try.
Phone: Pixel 3a (Purple-ish).
Build Log:
If it was working right up until the driver update then it's most likely the updated driver doesn't like your hardware.
Do you remember the version you were running prior to the update? DDU and re-install the old driver.
i dont remember the driver but i can try some older one
Sometimes you have to be careful when updating drivers with old hardware. It won't always go according to plan. Although, I've been told NVIDIAs driver still supports cards much older than the 760 so it's strange to hear you're having these problems.
When you uninstall the driver does the GPU still report Error 43?
yes
yes
Well, pull an older driver and see if that changes when you install it.
should i start with https://www.zotac.com/ee/files/download/by_product?p_nid=334012&driver_type=235&os=981 , or an update from nvidia web site(https://www.nvidia.com/en-us/geforce/drivers/)?
19 minutes ago, Windows7ge said:
I would pull it strait from NVIDIA.
ok so i installed  nvidia driver version 441.87 and my gpu switch from all good to code 43. you know the sound when a device is detected, my pc does that sound, i see my that my gpu is ok in device manager, few second after, i hear the sound, then my gpu is not ok(code 43), then few second i hear the sound and my gpu is ok, and the sound goes and it repeat this sequence again and again, do you understand, english is not my first language sorry.
Do you have a spare GPU? Or another computer you could put this one in for testing purposes?
3 hours ago, Jarles said:
yes i have a brand new pc, r5 3600, rtx 2060, is it dangerous to put a defectuous gpu is my new pc?
Assuming everything was working prior to the update I find it hard to believe the GPU is defective.
Though to answer the question in rare circumstances when a GPU is defective the possibility does exist that it could take out other hardware. The risk is very low but if you still don't want to chance it is there any other PC you could use?
no there is not, ill buy another one on  the used market.. i appreciate your help a lot thank you
I'm still not convinced the GPU is defective. Do you have an extra HDD around? If you installed Windows to it and then the NVIDIA driver does the behaviour change?
