memory channel vs speed
Go to solution Solved by minibois,
2 minutes ago, Arshia said:
which one do you think is better?
32 GB (1x 32GB) DDR4 3200MHz Samsung / Crucial
32GB (2x 16GB) DDR4 2666MHz Hyperx / Vengeance
2x16GB 2666Mhz would be faster than 1x32GB 3200Mhz, just because there would be more throughput of speed due to the dual channel structure.
dual channel. will effectively get double the bandwidth, which frequency wont be able to beat.
Phone: Pixel 3a (Purple-ish).
Build Log:
