Specs:
Ryzen 5 3600 - CPU
Asrock B550M Steel Legend - MOBO
Nvidia RTX 2060 (Zotac) - GPU
550W Thermaltake Smart BX1 - PSU
Corsair 16GB R (x2 8GB) - RAM
Kingston 120GB - SSD
Silverstone Fara R1 - CASE
Put everything together quite easily, but she's not posting. Cable management is horrendous because I want to get it working first.
We'll see if I lose money on this.
https://linustechtips.com/topic/1224636-first-build/
I would follow the troubleshooting steps in the troubleshooting subforum, and then post it under that forum if they do not work
PC
Ryzen 5 2600 Stock
Sapphire Nitro+ Special Edition Radeon RX580 8GB (Would Recommend)
Gigabyte B450M DS3H (Don't recommend)
Hyper 212 RGB Black Edition
Corsair Vengeance LPX 2x8GB DDR4 3000MHz CL15
Phanteks P300 (Would Recommend)
Kingston A400 240GB SSD
Seagate BarraCuda 1TB HDD
Corsair CX550M 550W  80+ Bronze
Deepcool FH-10 Fan Hub
3x BeQuiet Pure Wings 2
https://uk.pcpartpicker.com/user/marmour/saved/QTY3ZL
Peripherals
LG 24MK400H
Logitech G413 Carbon
Logitech G305 (AAA Adaptor - 10g reduction) (Would recommend)
Logitech Z150
HyperX Cloud II (Would recommend)
Moto G5 Plus (Webcam)
Phone
Pixel 3A XL (Would recommend)
*Useful Link* PSU Tier List: https://linustechtips.com/main/topic/1116640-psucultists-psu-tier-list/
https://linustechtips.com/topic/1224636-first-build/#findComment-13842350
I've troubleshot over a few days- diff ram, ram slots, running w/o excess devices connected, etc. same exact results despite trying pretty much everything. I don't want to turn this into a troubleshooting log but I've tried so much already lol
https://linustechtips.com/topic/1224636-first-build/#findComment-13842373
Just now, SPARTAN VI said:
Is it powering on at all? E.g. fans spin and LEDs on? Or is completely dead/silent when pressing the power button (or shorting the power switch jumpers)?
MOBO and CASE LEDs work, GPU CPU CASE fans spin, but no display output from the GPU (hdmi and DP). My connected mouse and kb are not getting any power. CASE power button allows me to turn it on and off. Reset button works as well. When removing my CPU 8 pin connector the CASE power button didn't work, but then it would work when I reconnected it.
Probably should move this to troubleshooting anyway 😬
https://linustechtips.com/topic/1224636-first-build/#findComment-13842405
That's a good sign, at least it's powering on. Do you have a 4-pin buzzer so we can determine the POST / beep code? If not, I recommend you buy one for your kit.
Can you share a photo of your I/O area / back panel on your most recent attempt so we can see how your input/output devices are connected?
https://linustechtips.com/topic/1224636-first-build/#findComment-13842453
The back I/O just had my kb and mouse connected, but I tried powering on with them disconnected and it still had the same results. I don't have a 4 pin buzzer but I will consider getting one. My MOBO has red error LEDs, and the ones that were glowing solid red were DRAM and CPU.
https://linustechtips.com/topic/1224636-first-build/#findComment-13842587
Have you tried RAM in only the second slot from the CPU? I saw one with it in the very last slot which would only be used with 2 or 4 sticks.
Project Hot Box
Oppbevaring
Why is the 5800x so hot?
https://linustechtips.com/topic/1224636-first-build/#findComment-13843553
Redo the RAM as people have said.
Also, you might need to reseat the CPU or tighten/loosen the threads of the screws. Mounting pressure can be a reason for the errors.
If you do reseat the CPU, check/take a picture of the CPU and the heatsink to see how much contact there was with the thermal paste.
https://linustechtips.com/topic/1224636-first-build/#findComment-13844631
  Hide contents
I tried both channels of RAM that I had in every single slot. (I should have specified that)
https://linustechtips.com/topic/1224636-first-build/#findComment-13845254
Yeah, with the RAM I tried both channels in every slot with the same results.
I reseated the CPU twice but I'll certainly make note of the mounting pressure. I initially had it pretty pressed up, but the next time around there was less contact with the same results.
https://linustechtips.com/topic/1224636-first-build/#findComment-13845261
37 minutes ago, It_Never_Posts said:
Thanks! It ended up being two bad RAM sticks! I really appreciate all of your help!
That's great! Back to it being a build log! That'll look really good with some cable management like you said. Time to go all OCD!
Project Hot Box
Oppbevaring
https://linustechtips.com/topic/1224636-first-build/#findComment-13845492
  • 3 weeks later...
