Excel Conditional Formatting Formula Help
Solved by IntMD,
My excel is pretty rusty for stuff like this, but i think you want something like this in the conditional formatting as the formula, and you'll need to do another rule for Set 2 but pretty much the same deal but different for the set two relative cells and name, where the C2:C35 is the range of your values so you could probably do the whole column if needed.
=IF(AND($O$3="Set One"),((C2:C35)>$L$3))
