How do I replace a hard drive?
Solved by SupaKomputa,
1 minute ago, Myxtro said:Yes basically. Should I reinstall al the programs currently on D:\ on the new drive?
No, as i said as long as the drive letter and structure is the same it will work.
Only reinstall if you want to change the drive letter, like C to D.
Assuming the new HDD will replace the old one, you can change it to D when you unplug the old one.
