First Build, Ideas
Go to solution Solved by FreelanceNewbie,
okay, i will do some more research. I am not in a hurry just checking out. will start a new thread if i have any other questions
Budget (including currency): $1000 US
Hey just wanted input on this build i am attempting. This would be my first attempt at such, so what are your thoughts and what i can improve without much cost difference. I know it's already a little over budget, but i can work with it. Also i will get additional storage space later. I want to run a VR headset, dual monitors and gaming.
Asus TUF GAMING X570-PLUS (WI-FI) ATX AM4 Motherboard
AMD Ryzen 5 3600 3.6 GHz 6-Core Processor
Gigabyte GeForce GTX 1660 SUPER 6 GB OC Video Card
Corsair Vengeance RGB Pro 32 GB (2 x 16 GB) DDR4-3200 CL16 Memory
Samsung 860 Evo 1 TB 2.5" Solid State Drive
Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler
Cooler Master MWE Gold 650 W 80+ Gold Certified Fully Modular ATX Power Supply
Lian Li LANCOOL II-X ATX Mid Tower Case
https://linustechtips.com/topic/1222846-first-build-ideas/
PCPartPicker Part List
CPU: AMD Ryzen 5 3600 3.6 GHz 6-Core Processor  ($171.89 @ Amazon)
Motherboard: MSI B450 TOMAHAWK MAX ATX AM4 Motherboard  ($124.99 @ Best Buy)
Memory: G.Skill Aegis 16 GB (2 x 8 GB) DDR4-3200 CL16 Memory  ($57.99 @ Newegg)
Storage: Crucial P1 1 TB M.2-2280 NVME Solid State Drive  ($104.99 @ B&H)
Video Card: Sapphire Radeon RX 5700 XT 8 GB PULSE Video Card  ($399.99 @ Amazon)
Case: Fractal Design Meshify C ATX Mid Tower Case  ($98.99 @ Walmart)
Power Supply: Cooler Master MWE Gold 650 W 80+ Gold Certified Fully Modular ATX Power Supply  ($99.99 @ Best Buy)
Total: $1058.83
Generated by PCPartPicker 2020-07-16 07:31 EDT-0400
https://linustechtips.com/topic/1222846-first-build-ideas/#findComment-13828085
How are you over a $1000 budget with that? Do you have a parts list that includes prices?
CPU: AMD Ryzen 9 9950X3D · Cooler: Noctua NH-D15S Chromax.black · Motherboard: Gigabyte Auros X670 Elite AX · RAM: G.Skill Flare X5 64GB (2 x 32GB) DDR5 6000MHz CL30 · Graphics Card: Zotac NVIDIA GeForce RTX 4070 Super Twin Edge OC 12GB · Boot Drive: 1TB XPG Gammix S70 Blade NVMe SSD · Game Drive: 2TB WD SN850X NVMe SSD · PSU: Seasonic Focus GX V3 1000W 80+ Gold · Case: Fractal Design North Mesh · Monitor: MSI Optix MAG342CQR 34” UWQHD 3440x1440 144Hz · Keyboard: EPOMAKER x Aula F99 Wireless Mechanical Keyboard · Mouse: Logitech G309 Lightspeed Wireless Gaming Mouse
https://linustechtips.com/topic/1222846-first-build-ideas/#findComment-13828087
https://linustechtips.com/topic/1222846-first-build-ideas/#findComment-13828089
Total: $1058.83
Change the board to a B550 Pro4 and it's perfect.
I would personally not buy an XFX cooler as they did duck up the design and the Pulse is just better
https://linustechtips.com/topic/1222846-first-build-ideas/#findComment-13828091
