Thermaltake V200 RGB
smunee
Is it possible for me to put any fans on the bottom of my case. The case is a Thermaltake V200 RGB (if the RGB makes a difference)
No
A simple look at the website will tell you this
FAN SUPPORT
Front:
3 x 120mm, 2 x 140mm
Top:
2 x 120mm, 2 x 140mm
Rear:
1 x 120mm
RADIATOR SUPPORT
Front: 1 x 240mm, 1 x 280mm
Rear: 1 x 120mm
(2020 Version)
Front: 1 x 360mm, 1 x 280mm
Top : 1 x 240mm,
Rear: 1 x 120mm
CLEARANCE
CPU cooler height limitation: 160mm
Are you having cooling issues?
What are your specs?
