The 2060 is technically slightly faster. If you're streaming and you use nvec go for the 2060.
What other specs ? Budget? And what are they priced at?  What about the 5700? Which is faster than both of these cards.
Edit. And why is this is cpu's section?
Edited by TofuHaroto
Phone: Pixel 3a (Purple-ish).
Build Log:
1 minute ago, Kisai said:
Better" is relative.
Wouldn't really use a stress test when we're comparing gpus that are close to each other.
3 minutes ago, xyan3 said:
im using ryzen 3 3300x
Budget ?
Build Log:
That's exactly why I said it.
https://gpu.userbenchmark.com/Compare/Nvidia-RTX-2060-vs-Nvidia-GTX-1070-Ti/4034vs3943
11% difference in favor of the GTX 1070Ti on this one.
Are you unironically using user benchmark as a trust worthy source lol..
Both if these gpus would work depending on the workload.
Need the new nvec ? 2060/super.
Want the bigger frame buffer for some reason. 1070ti. One is cheaper the the other. Then get that.
And user benchmark is not really a source. It's always wrong. I wouldn't trust it. And in fact. No body does lol..
Build Log:
You're using a known troll website with fake data because....?
42 minutes ago, xyan3 said:
which is better 1070ti or 2060 or are they both good in diff things
The 2060 or RX 5600 XT are better.
but its apparently much cheaper
It's cheaper and has the same performance. Look for the 5700 as well.
Build Log:
