I really dislike how Youtube's volume is so difficult to get right at low volumes, and I with the volume slider was 2 times larger.
I had an Extension with Linear Volume but it disappeared somehow.
Anyone know which Extensions have Linear youtube volume? Can't seem to find it on the site.
Logi MX KEYS - high quality low profile membrane keyboard  - perfect for gaming imo 🙂
https://linustechtips.com/topic/1221582-chrome-youtube-linear-volume/
If this is to do with the varying production values/skills of the channel owners, that P***es me off, too.
**I frequently edit any posts you may quote; please check for anything I 'may' have amended.**
Current PC spec. in my profile.
Can I realistically call myself a gamer, if I only play ONE, twenty year old game...?
Did you test boot it, before you built in into the case?
WHY NOT...?!
Your Sig @Eighjan, I feel your pain. I work in IT and so many ppl rebuild the whole laptop and then find that something is wrong.
Best tip: Never screw in everything until you know it works, doesnt matter what device it is.
