How do you orient your PC case when putting the motherboard in
16 members have voted
  1. 1. How do you orient your PC case when putting the motherboard in
Horizontal. Unless I have one of Corsair's cases where there's a little lock at the middle.
Phone: Pixel 3a (Purple-ish).
Build Log:
https://linustechtips.com/topic/1221563-pc-case-building/#findComment-13817219
Normally horizontal, but I went with "both" as there are occasions where its made more sense to do it vertically.
[ P R O J E C T _ M E L L I F E R A ]
[ 5900X @4.7GHz PBO2 | X570S Aorus Pro | 32GB GSkill Trident Z 3600MHz CL16 | EK-Quantum Reflection ]
[ ASUS RTX4080 TUF OC @3000MHz | O11D-XL | HardwareLabs GTS and GTX 360mm | XSPC D5 SATA ]
[ TechN / Phanteks G40 Blocks | Corsair AX750 | ROG Swift PG279Q | Q-Acoustics 2010i | Sabaj A4 ]
P R O J E C T | S A N D W A S P
6900K | RTX2080 | 32GB DDR4-3000 | Custom Loop
https://linustechtips.com/topic/1221563-pc-case-building/#findComment-13817605
