Need help deciding
The RX 580 is faster than the GTX 1060 - much faster now, actually. It competes with the 1660, due to much better software updates.
The CPU performance is theoretically identical... Skylake has about 10% better IPC than Haswell, but the 4590 has a boost clock of about 10% more, so that's void. DDR4 single channel vs DDR3 dual channel, I'm guessing is too similar to care about.
Something you should look into is the Skylake Base Clock Overclock. In an error, Skylake chips were accidentally unlocked for Base Clock Overclocking. See if your motherboard supported it back when it happened, then it's just a matter of rolling back to that older BIOS (Intel patched it out) and tweaking a few Windows settings and you're set. I know people who were running i3 6100s at like 4.7 GHz and beating up the 6600k lol.
