Hi! I have the p400A case with a 160mm CPI cooler clearance, would I be able to fit a dark rock pro 4 in there? I know the specs say it is like 2 mm too large, but I assume there is some headroom that the manufacturers built in. Otherwise, I was thinking of a scythe fuma 2 as a replacement. Thanks!
https://linustechtips.com/topic/1220653-which-air-cooler/
I mean if you shoved the side panel/window on it might flex the board back by 2mm if you managed to fit it, but Id rather be safe than sorry and get something thats within spec
CPU: i5-4690k @ 4.4 GHz | RAM: 12GB DDR3 1333MHz | GPU: Sapphire Pulse RX 580 4GB
https://linustechtips.com/topic/1220653-which-air-cooler/#findComment-13809607
naah don't worth  risk,tht cooler is huge...buy mugen 5,arctic freezer (this one is smaller) but check the clerance.
what cpu u have?
Please do not take offence for my apparent confusion or rudeness,it's not intent me to be like that,it's just my BPD,be nice to me,and I'll return twice better,be rude and usually I get easly pissed of...I'll try to help anyone here,as long as it's something I dealt with,and even if you think I'm rude or not polite,forgive me,  it's not me it's my BPD.
Thanks for understanding.
https://linustechtips.com/topic/1220653-which-air-cooler/#findComment-13809697
I recommend the Fuma 2, Mugen 5 Rev.B, or Arctic Freezer 34 eSports DUO.
MAIN PC:
CPU: AMD Ryzen™ 7 7800X3D Motherboard: Gigabyte B650 Eagle AX CPU Cooler: EVGA CLC 240 GPU: EVGA RTX 3080 FTW3 Ultra RAM: TEAMGROUP Expert T-Create 32GB (2x16GB) 6000Mhz CL30
Case: CoolerMaster TD500 Mesh PSU: Thermaltake GF1 PE 750w Storage: 1TB Western Digital Blue 3D + 1TB Crucial P1 + 1TB ADATA XPG Gammix S11 Pro + 4TB Seagate Barracuda 5400RPM OS: Windows 10 Home
Headphones: Philips SHP9500s   Keyboard: Corsair K70 RGB MK.2 Cherry MX Red Displays: Gigabyte M27Q (27" 1440p 170hz IPS), Samsung UN32EH4003FXZA (32" 768p 60hz TV)
Former parts that I've used:  Intel® Core™ i3-9100F, Intel® Core™ i9-9900k, Asus Dual OC 2080, Gigabyte Aorus Master 3080, Gigabyte Gaming OC 3080, EVGA XC3 Ultra 3080, EVGA FTW3 Ultra 3080 Ti, EVGA 3060 XC, ASRock Z390 Phantom Gaming 4-CB, Gigabyte Z390 Aorus Pro Wifi, ADATA XPG 16GB (2x8GB) 2400Mhz CL16, Corsair Vengeance 32GB (4x8GB) 3000Mhz CL15, Scythe Fuma 2, Acer XG270HU.
https://linustechtips.com/topic/1220653-which-air-cooler/#findComment-13812570
