no, 100rpm shouldn't be a problem, but may be below the fans minimum operating voltage.
desktop
r5 3600,3450@0.9v (0.875v get) 4.2ghz@1.25v (1.212 get) | custom loop cpu&gpu 1260mm nexxos xt45 | MSI b450i gaming ac | crucial ballistix 2x8 3000c15->3733c15@1.39v(1.376v get) |Zotac 2060 amp | 256GB Samsung 950 pro nvme | 1TB Adata su800 | 4TB HGST drive | Silverstone SX500-LG
HTPC
HTPC i3 7300 | Gigabyte GA-B250M-DS3H | 16GB G Skill | Adata XPG SX8000 128GB M.2 | Many HDDs | Rosewill FBM-01 | Corsair CXM 450W
https://linustechtips.com/topic/1220091-gpu-fan-rpm/#findComment-13804838
fan rpm is linked to voltage, either direct or pwm, and most fans don't run below ~5v. Like I have some noctua fans and at their lowest voltage they run around 300 rpm, give them any less juice and they won't run.
desktop
HTPC
https://linustechtips.com/topic/1220091-gpu-fan-rpm/#findComment-13804887
