Hey. I cleaned dust in my case for the second time after the build (1 year by now) and tried to boot up. The dram led on mobo was lit and stuck. No boot and other stuff like aio and gpu-fans and etc are working but the dram yellow light won't go away and i cant boot. I tried different slots-single module- used MemOK everytime.cleared cmos, but still the same.
Is my ram damaged or motherboard? I was very careful doin all the cleaning
Searched alot still nothing !
My spec is
Asus z370 prime a ii
I7 8700k
2*8g 3200 giel evo forza ddr4
Asus rtx 2060 oc
Edited by Gh0stin
https://linustechtips.com/topic/1220003-dram-yellow-light-need-help/
How many sticks of RAM do you have? What kind?
What motherboard?
Do you have any other RAM you could toss in to test with?
42 minutes ago, Gh0stin said:
My bad post edited
Do you have any other RAM you could install just to see if it'll POST?
