Which CPU should i get
10 members have voted
  1. 1. Which CPU should i get
    • Ryzen 5 3600
      6
    • Ryzen 5 2600
      1
    • Ryzen 5 1600
    • Other (comment)
      3
Since the 3600 has the best performance of them all it's the obvious choice,
Yes it's a little bit overkill but still a reasonable choice.
A PC Enthusiast since 2011
AMD Ryzen 7 5700X@4.65GHz | GIGABYTE RTX 3080 GAMING OC | 4x 8GB Micron Rev.E (D9VPP) 3800MHz 16-19-14-21-58
https://linustechtips.com/topic/1219597-cpu-for-1660-ti/#findComment-13800329
