Help for graphics
Solved by megalodonkatsu,
27 minutes ago, VenomRaptor17 said:i am triyng to get my display to run and keep minimum load on the external gpu so it doesnt even show the igpu on the device manager imma bit confused...i am confused that is my igpu working or not and how to check on it...i think my external gpu isnt letting me use the igpu so guys find me a solution pls @megalodonkatsu @PeachGr @Jurrunio
As long as you're not playing games or doing anything graphically intensive, the load on your GPU will be negligible. If I understand it correctly, you're basically asking for a laptop feature called NVIDIA Optimus, where the iGPU is used to save battery life. Honestly, just use your regular graphics card and don't worry about it.
