Hello There!
I built a computer around November last year. Although it works perfectly, sometimes when I'm playing I can heard "weird noises". So I was thinking whether it could be the PSU or the GPU... my bet is the GPU which is an RTX 2070.
Here's the youtube link for a video in which I try to make the weird noises happen: https://youtu.be/PuwPCb8iY5Y
In the video, I have Portal 2 open in a window and a terminal displaying GPU info every 2 seconds. You will notice that when the terminal is focused, the gpu's power usage drops and the noise stops. If I place the mouse inside the game's window, the gpu's power usage will increase, as expected, and the noise will start. I put my phone near the GPU at the end and I think it's more noticeable at that point in the video.
Now, I searched a little and I saw that it could be Coil Whine... But, what do you guys think about it? Do you think the GPU should be generating this weird noise? Or... maybe it's the PSU?
By the way, I've played a lot since I bought this in November... nothing major occurred but I'm kind of getting worried about it.
Specs (don't know if it can help at all but):
CPU: Ryzen 7 3700X (3.6GHz I've disabled that auto "overclock" because I don't think it's necessary).
RAM: 32GB 2400MHz
Motherboard: MPG X570 Gaming Plus (MS-7C37) (MSI)
GPU: RTX 2070 (Gigabyte - Windforce)
PSU: EVGA 750 BQ
https://linustechtips.com/topic/1219242-possible-problem-on-rtx-2070/
15 minutes ago, BlueScope819 said:
Sounds like coil whine to me. It's pretty normal. i have a Titan XP that does it way worse than that, you are good.
Sadly I agree with BlueScope819 I have a 1070ti and when its pushed maxed (oc and powerlimit) then it gets pretty loud. You can try undervolting it (run same clock lower voltage) and that tends to help A LOT.
