It's probably an unstable oc. Change your settings.
https://linustechtips.com/topic/121915-overclock-help/#findComment-1623118
Where was your last stable OC? 3.1?
Main Rig:
AMD FX 8320 @4.5Ghz  8GB Corsair Vengeance LP Blu 1600Mhz Sapphire Vapor X HD 7950 3GB 120GB Samsung 840 Evo  Asus M5A99FX PRO R2.0
Corsair 600T Graphite Corsair H80i Corsair CX600 2x LG 24 inch LED @1080p Logitech G700s CM Quickfire TK (Brown)
Home Server:
A4 6300 @3.7Ghz 5GB Kingston/Crucial DDR3 1600Mhz 1TB WD Green 2TB Seagate Barracuda
500GB WD Blue 2x Gigabit NIC Antec 300 OCZ 500w PSU Gigabyte F2A68HM-HD2 R1.1
https://linustechtips.com/topic/121915-overclock-help/#findComment-1623134
what do you mean and what is prime 95
If you plan on overclocking then you probably should invest in a better cooler. stock coolers are ment to keep the cpu cool under the standard speeds. overclocking can greatly increase your temp and can cause several issues. And prime95 is a stress test program ment to push your cpu to see if any of the cores fail under load. If a core should fail then it will say and that means that your cpu is unstable.
AMD diehard & Nvidia Enthusiest
https://linustechtips.com/topic/121915-overclock-help/#findComment-1623204
I used amd overdrive to oc and I did like a 20 min stress test but I didnt know how to interpret the results
https://linustechtips.com/topic/121915-overclock-help/#findComment-1623222
I run it normally on 3.0 I havent really tryed 3.1 just in case and since I dont have the money id like to be able to push it
Well is it stable at 3.0? Any lines or issues? Bring it down to 3.1 and run prime95 on blend for at least 30 mins. If there are no issues, then try and raise the voltage a little, and then put it up to 3.2
Main Rig:
Home Server:
https://linustechtips.com/topic/121915-overclock-help/#findComment-1623226
I can't help you then...if it were me, I'd use the BIOS settings to overclock
Main Rig:
Home Server:
https://linustechtips.com/topic/121915-overclock-help/#findComment-1623230
it's stable at 3.0 and it won;t let me turn up the voltage anymore
https://linustechtips.com/topic/121915-overclock-help/#findComment-1623244
I agree. overdrive is okay but is know for unstability. Try overclocking your northbridge in the BIOS. It is a far more stable overclock then using a program. Also i still would get a aftermarket cooler. you can get a decent one for $40 USD on newegg. Becuase running a hot cpu can cause permanent damage.
https://linustechtips.com/topic/121915-overclock-help/#findComment-1623258
Well I guess if you are using AMD overdrive then you are stuck at 3.0. Especially with that cooler- Buy a Hyper 212 for 40 dollars
Main Rig:
Home Server:
https://linustechtips.com/topic/121915-overclock-help/#findComment-1623266
It didn't seem to be getting that hot but i'm wondering if i'm going to go ahead and spend money should I just save up for a better processor cause I really don't have the money
https://linustechtips.com/topic/121915-overclock-help/#findComment-1623268
so how can i stable it other than to turn up the voltage
You really can't. Applying more voltage will stabilize your cpu but also cause it to get hotter which is why the more you overclock the better cooler you need.
https://linustechtips.com/topic/121915-overclock-help/#findComment-1623297
Gonna have to speed at least 80 for a better CPU, and you won't be able to overclock that without a cooler as well
Main Rig:
Home Server:
https://linustechtips.com/topic/121915-overclock-help/#findComment-1623300
70 is as high as you want it to get.
Main Rig:
Home Server:
https://linustechtips.com/topic/121915-overclock-help/#findComment-1623309
Well seeing as you have a small budget , then go for the Hyper 212. Can't beat it for the price
Main Rig:
Home Server:
https://linustechtips.com/topic/121915-overclock-help/#findComment-1623430
