Need help for choosing GPU
Solved by HardStroke,
2 hours ago, Israel Prakash said:Gxtogotoxagsxzjfusfu
Gtx 1080 or Titan rtx or Quadro 4000
Not sure how you got to those choices but ok...
If the 'Israel' in your name is the place you live in and you use your pc for gaming i suggest you go with a good version of the 2060 super/2070/2070 super or wait for the 3000 series.
because the only cheap 1080 is a founders edition one and the other single option that i see is a water cooled version at a price of a high end 2080 ti.... unless you go on 'yad2' or something like that and you got a good deal on a second hand card.
That is if you do live in israel and if you want a 1080.
As for the quadro and the titan we really need to know your use and specs so we could help you
