Hi,
i am planning to apply liquid metal thermal paste to my dell g7 7790, just saw Linus’ video about how to apply and saw him applying a non-conductive layer and tape on small components around the CPU die. I just wonder what if there are any drawbacks of doing so?
thanks
https://linustechtips.com/topic/1218717-insulating-components-around-cpu-die/
8 minutes ago, spysoaa said:
Hi,
thanks
Tape is good but if the adhesion of the tape isn't sealed around the edge isn't complete or it fails overtime liquid metal can wick it's way under. I personally recommend to apply a coating, either getting a proper conformal coating for even just using clear acrylic nail polish is acceptable.
An idea is to use some thing like thumb putty around the die area to create a seal, how ever I have yet to have liquid metal fail on me in terms of leakage, even in laptops. Be carefull.
At me or quote me, I want to hear your opinion.
Hopefully anything I say is factually correct. Sorry for any mistakes in advanced.
