750 ti Help.
Go to solution Solved by JAKEBAB,
not exactly.. you have to plug in power pins rather than putting it into the PCI just that way it will have no power to run
EDIT: Depends on your PSU.. mostly stock pc's have 300w or even 400w
power pins? what are u talking about?
Op if u get a reference design u should be ok as it doesnt require a pcie plug it gets its power threw the pcie slot but make sure your psu is about 300w+
depends on the hardware you've got.
What hardware are you using right now?
I am not sure, all I know is that it is a duel core i3 and some oem motherboard.
U FOKEN WUT M8 ILL REK U M8 ILL BEAT UR ASS ACROSS THE PLANET ANS THEN SELL YOU TO THE MAFIA WHERE THEY WILL MAKE YOU THIER BITCH U FGT
https://linustechtips.com/topic/121785-750-ti-help/#findComment-1621369
I thought the 750ti can run off PCI power
(NOW)War Horse:
CPU: AMD FX-6300 | Motherboard: MSI 970A-G43 | RAM: Corsair Vengeance Dual Channel 8GB 1600Mhz | GPU: MSI R7790 | Case: Dazumba D-Vito 903 | HDD 1 & 2: Seagate 1TB and Seagate 500GB | PSU: Corsair CX600
(WAS)Old Coop:
CPU: Intel C2D E7500 | Motherboard: Gigabyte G31M-ES2L | RAM: V-Gen 4GB Dual Channel | GPU: Galaxy GT210 | Case: Power-Up ??? | HDD: Seagate 500GB | PSU: Power-up 500W
MyAnimeList Profile | Heaven Society | HEIL THE MIGHTY AND POWERFUL LINUS | My Blog 'Unfinished Pieces' | Code of Conduct
https://linustechtips.com/topic/121785-750-ti-help/#findComment-1621397
You might be okay. PC Perspective had an article where even a 250W PSU perfectly adequate for some prebuilts they put 750 Ti's into.
EDIT: http://www.pcper.com/reviews/Graphics-Cards/Upgrade-Story-Can-GTX-750-Ti-Convert-OEMs-PCs-Gaming-PCs
https://linustechtips.com/topic/121785-750-ti-help/#findComment-1621406
https://linustechtips.com/topic/121785-750-ti-help/#findComment-1621431
search for "system information" in the start menu to find out what motherboard you have. "System Manufacturer" is the motherboard manufacture and "system model" is the motherboard model.
in system information you can also see how much ram you have under "install physical memory (ram)" you can also see the exact processor including model number in there.
Download gpu-z to find out what graphics card you have.
Open up your case and find out what power supply you've got aswell.
Let me know when you have all of this information. CPU, motherboard, ram, gpu and power supply
https://linustechtips.com/topic/121785-750-ti-help/#findComment-1621433
This helped me a lot thanks.
https://linustechtips.com/topic/121785-750-ti-help/#findComment-1621447
If you get a 750ti without the 6 pin, you'll have no issue.
With the 6 pin, you may or may not depending on your PSU
EVGA has a really nice 750ti (SC version), that has a nice aftermarket cooler, a nice overclock, and doesn't require the connector.
Case: Lian Li PC011-D - CPU: 3900x - GPU: 2080ti Reference - Mobo: Gigabyte - Ram: Corsair 4x16gb 3200MHz - SSD: 2TB Samsung Evo NVME
https://linustechtips.com/topic/121785-750-ti-help/#findComment-1621452
Thanks for the recommendation I will most likely buy this one.
https://linustechtips.com/topic/121785-750-ti-help/#findComment-1621499
