Grainy quality when streaming
Go to solution Solved by Moonzy,
On 7/8/2020 at 9:16 PM, narrdarr said:
grab Twitch Bandwidth Test Tool: https://r1ch.net/projects/twitchtest
slap in your twitch key
tcp select OBS recommended
select region
time can be short
run it a couple times
watch for the one that performs the best over the couple runs
most important first is
quality
ping
bandwidth
here's the result:
This will tell you what what server you should use and what bit rate you should use.
Set the server in OBS under stream settings
though im trying to stream to youtube... ahahaha
The best x264 settings:
Rate Control: CBR
Bitrate:6000 (non-partners) / 8000 (partners)
CPU Preset: super faster
hmm, if i use Super fast, will it be more blurry?
i thought the slower the better, up to a point of course.
i did some further test
i cropped out a short clip in shotcut and exported it with Youtube preset
these are the results, the exact same frame
source (uploaded video):
Youtube: link to video
idk what this means but i hope it helps somewhat, it's the youtube "stat for nerds"
also here's some video of MHW that someone uploaded, it's much clearer for some reason
edit: i think... it's because of the codec youtube is using
mine's avc, while the video i linked is vp9
edit 2: seems like youtube is favouring established creators by allowing VP09 codec for their uploads, while using avc on smaller creators, ah well i guess my problem is solved
AVC:
VP09:
edit 3: i tested streaming on 1440p (upscaled from 1080 in obs) to force youtube to use VP09, it worked, it's crystal clear now... relatively
case closed
I've been trying to stream monster hunter world on OBS to youtube for a while now
no matter what i try, the footage is grainy
i'm wondering what i can do to improve my stream quality
rig:
CPU: R9 3900x (cores at 3.7-3.9ghz)
RAM: 2x8gb 3600MHz CL18
GPU: RTX2070 Super
full spec: https://pcpartpicker.com/list/YZvFGc
setting i've tried:
i also tried 9000Kbps, as well as software(x264) encoder on slow preset, around 7000-8500kbps tested
all produced grainy footage
is there some setting im missing?
edit: i tried recording locally using the same setting as stream, it seems better than when i stream it to youtube, perhaps it's youtube's side?
-sigh- feeling like I'm being too negative lately
https://linustechtips.com/topic/1217748-grainy-quality-when-streaming/
1 minute ago, narrdarr said:
What is your internet speed, what router do you have, and are you wired or wireless?
my internet speed is 30mbps down 10-15mbps up
my router is an Asus RT-AXC55UHP, and im connected to it thru 1Gbe LAN
12 hours ago, narrdarr said:
considering you have a 3900x with a gtx 1070 how well does cpu encoding(x264) work compare to gpu encoding(nvenc)?
i tried encoding on software x264, nvenc on both my GTX 970 and RTX 2070S, all 3 produced blurry results when im moving (fighting monsters)
they're fine when im standing idle, but it takes like few frames for it to slowly get back the details (ie lines in the bricks)
i tried recording locally with 6000kbps, both 720p and 1080p, 60fps
the local recording seems clearer than when i uploaded it to youtube, seems like youtube is doing some of its own compression
i will try streaming to twitch, see how it goes
also, if u have any idea how to reduce youtube's compression (i've seen decent looking MHW gameplays on there that isnt nearly as blurry), do let me know
Nvenc should mostly be the way to go for you.
look-ahead should be on and leave max b frames @ 2 this should help. But wouldn't use it with the 970 encoding. the 2070 should be fine.
bit rate simply the higher the better, but if you set it to high and your internet speed cant handle it you stream will lag or want to buffer.
so maybe like 7-8k (fyi most people stream 1080@60 are usually between 12-15k)
under the video tab
set setting to
1080
1080
try lanczos or bicubic even tho your not downscaling
If you had a higher res monitor downscale would help but its only 1080 so cant really down scale unless you want to stream at 960 or 720
For your recording and uploads to TY. Usually when the video first gets upload it always looks worse as it first gets uploaded as SD but it will be better later and change to HD.
but set the
recording format to mp4
bump up the bit rate
and enable look-ahead
You can try up-scaling the video before uploading. Then let youtube compression downscale.
this should help
dont twitch limit people at 6000? and affiliates at around 8000? their stream looks clean compared to mine at 1080p60
im using lanczos already
thanks for the suggestions, i'll test them out and let you know how it goes
this should help
quote for notifying
disclaimer: i know it's a flawed test, im no expert in these kind of stuffs
i used a service called restream to stream simultaneously to both youtube and twitch, so that both get the same video
my stream setting: 720p60, nvenc, 6000kbps, keyframe = 2
then i downloaded the youtube video from youtube studio, and did a screen capture for the twitch video (at 60000kbps nvenc)
and then i used shotcut to combine both videos, align frame to frame, then export them at lossless quality into a single video file
these are the results: (left = twitch, right = youtube)
idle: https://imgur.com/a/Z8fPV27
moving: https://imgur.com/a/W9S3BD8
do note that the youtube stream slowly becomes more and more blurry until a certain point, then it suddenly became clear again, and then repeat
it cycles like this for the entire video, each cycle lasts about 2-3 seconds, i think
so i think youtube is doing some compression, making it look way worse than what I'm sending
3 hours ago, Moonzy said:
quote for notifying
its its way of trying not to buffer.
try these settings
under output
encoder=nvenc
enable Enforce streaming service encoder settings
Bitrate doesn't matter(Enforce streaming service encoder settings=the streaming service will pull max amount for choice settings) this should test if it a compression issue of a bitrate issue.)
under video
1080
720
bicubic
try both 30 and 59.94
after testing with these setting
disable Enforce streaming service encoder settings
set bitrate 8k
test
30 fps and 59.94
On 7/7/2020 at 8:47 AM, narrdarr said:
under output
encoder=nvenc
i tried, still kinda blurry
but the bitrate still follows what i picked, according to OBS at least, i tried setting 8000 or 9000, it follows
under video
1080
720
bicubic
i tried both 1080 and 720p as output, i noticed 720p is significantly more blurry, even though same bit rate
which is kind of weird
i did not try bicubic as i was using bicubic before lanczos before all these
as for fps, i would love to stream at 60, or not at all, it's just a hobby after all haha
honestly im just bout to give up streaming mhw, or any fast paced games i guess
ok let approach this a different way
select region
time can be short
quality
ping
bandwidth
under video
1920x1080
1440x810
Lanczos
59.94 fps
under out put
disable- enforce streaming service encoder service
optional( i would enable)-look ahead
disable- psycho  visual tuning
your bit rate should be set to 50-60% of your bandwidth
are here are the setting for you to go with
Chose the following bitrates for 60FPS live streams at 810p (1440x810)
12000+kbps = 6000 (NVENC)
10000kbps = 5000 (NVENC)
8000kbps = 4000 (x264)
7000kbps = 3500 (x264)
6000kbps = 3000 (x264)
5000kbps = 2500 (x264)
The best NVENC settings:
Rate Control: CBR
Bitrate: 6000 (non-partners) / 8000 (partners)
Preset: High Quality
Profile: High Use
Two-Pass Encoding: Yes (look ahead)
Rate Control: CBR
select region
time can be short
quality
ping
bandwidth
here's the result:
Rate Control: CBR
AVC:
VP09:
case closed
thanks for the assist by the way, appreciated the effort
at least now i know if i ever wanna stream, i should use the hongkong server
Suggestion:
Be sure to use the tool since things can change at any time, although that location is shown to be good at the time testing was done that doesn't mean it would be good all the time period.
Each time you want to stream you can do a quick check to see what's good and go with what's best.
"If you ever need anything please don't hesitate to ask someone else first"..... Nirvana
"Whadda ya mean I ain't kind? Just not your kind"..... Megadeth
Speaking of things being "All Inclusive", Hell itself is too.
