Need assistance; Unbearably loud laptop engine noise
Solved by kelvinhall05,
Can you try unscrewing the fan and lifting it out of the chassis and see if it still makes that noise?
But honestly I'd just replace it. Should be like $10 on eBay at most.
Featured Topics
Emmanuel Katto ·
Posted in Peripherals3 -
1
2
Rusty Proto ·
4
WildOne ·
Posted in New Builds and Planning1 -
solarbear ·
Posted in Troubleshooting1 -
5
2
play_circle_filled
Latest From ShortCircuit:
Lian-Li, do this on all of your cases! - Lian-Li O11D x Lamborghini
