Either you typo'd or you meant that you r pc doesnt work correctly?
5 minutes ago, Nickolass said:
I turned on my pc, and I got a power cycle. Like when you first boot up a pc. And then everything else works fine. This wasnt happening yesterday or anything.
So was it not working yesterday but it is today?
 CHRISTIAN MEMBER
https://linustechtips.com/topic/1217702-power-cycle/#findComment-13784326
1 minute ago, Nickolass said:
But could it be an issue?
unlikely if its all working now without issues. if the issue replicates itself maybe, just saying its unlikely
Silent build - You know your pc is too loud when the deaf complain. Windows 98 gaming build, smells like beige
https://linustechtips.com/topic/1217702-power-cycle/#findComment-13784331
But it happens everytime I turn on my pc
Well thats a little different, I didn't pick that up from your original post.
https://linustechtips.com/topic/1217702-power-cycle/#findComment-13784335
2 minutes ago, Nickolass said:
No my pc works and everything turns on fine. I have a video of it if you would like me to post it
Ok so your topic is very confusing.
Is there an issue or not?
 CHRISTIAN MEMBER
https://linustechtips.com/topic/1217702-power-cycle/#findComment-13784341
It's just the RGB turning off, the rest obviously isn't. Probably initializing or something...
F@H
GPD Win 2
https://linustechtips.com/topic/1217702-power-cycle/#findComment-13784357
6 minutes ago, Nickolass said:
Thats what im asking. My pc has a poweer cycle everytime I turn it on. Heres a video
video0.mov
Ok you are not describing the issue very well. [I watched the video] It looks to me like there may be an issue BUT I cant tell. To me it looks like the pc is just doing self tests and it cycles up.
What part of this was the pc not doing before?
 CHRISTIAN MEMBER
https://linustechtips.com/topic/1217702-power-cycle/#findComment-13784360
It wasnt doing any of that, the fans would ram up and then back down while all the rgb is on and everything.
https://linustechtips.com/topic/1217702-power-cycle/#findComment-13784366
Since I dont have any rgb I cant speak directly to why it is doing this. I would check to see if there are any issues being flagged by the system.
You can also check your problem reports by going to:
 CHRISTIAN MEMBER
https://linustechtips.com/topic/1217702-power-cycle/#findComment-13784393
I cant fine problem reports
https://linustechtips.com/topic/1217702-power-cycle/#findComment-13784410
Are you seeing any other issues or side effects?
Also I have moved this topic to the Troubleshooting Sub-forum hopefully it will get someone's attention may help more than I can.
Edited by SansVarnic
 CHRISTIAN MEMBER
https://linustechtips.com/topic/1217702-power-cycle/#findComment-13784440
