I bought 4 sticks of G.skill flare x ddr4 cl 14 8gb each, total $140sgd on ebay. Can I still rma it?
The seller gave me the receipt of purchase.
The System can't read 2 and 4 slot of thr ram.
Edit : 3200mhz
Silent Cerberus - Fractal Design Core500,Ryzen R7 3700x,Scythe Fuma 2,Gigabyte Aorus B550i Pro AX,Crucial Ballistix Elite 3200mhz cl16 16gb,Adata XPG SX8200 nvme 512gb m.2 ssd,Lexar NS100 1tb ssd,Red Dragon RX5700 8gb(bio flashed 5700xt),Corsair SF600 SFX 600w 80+ platinum F-Modular.
Hades - dO.Ob Look into my eyes and see the dark eternal abyss that is your soul and pay for your hidden sins.
Cerberus - the hell hound that guards the gates of hell. Once you enter you'll never escape.
https://linustechtips.com/topic/1216941-need-help-with-bad-memory-sticks/
28 minutes ago, thisisderpy said:
You mean get a refund (sorry, I'm just not familiar with acronyms)?
No I ment replacement
27 minutes ago, gloop said:
No, pretty sure 'RMAing' is a replacement.
I think Gskill does replace
26 minutes ago, gloop said:
Is there any warranty left in the porduct?
Yes 1yr 3 months left
2 minutes ago, gloop said:
Try to boot using only 1 RAM stick at a time, switching them out as you go.
Can a single stick work?
I thought you need at least dual sticks.
Yes, a single stick can work. The downside is it will work in single-channel, which will limit performance.
That is not applicable here, though, as we are just testing to see if the sticks work or if it is the motherboard.
OK I'll give it a try thanks for the advice. 😊
Nope not the board I have 2 dead sticks of flare x
3 minutes ago, gloop said:
Ok, are the sticks all part of the same kit (eg. 4x8gb) or are they from different kits (eg. 2 2x8gb)?
Same kits
17 minutes ago, gloop said:
Then RMA the whole kit, and get a 4x8GB kit of 3200MHZ cl14.
OK, do I have to pay anything to rma?
First time rma my parts.
I’m pretty sure you don’t; the only possibility I could think of is the shipping from your place to the factory and then from the factory back to you.
Oh, shipping is fine I was thinking like part replacement fees lol.
