Good Replacement Fan for Hyper 212 Evo?
webmaestro
Seems like a lot of people replace the stock fan on the Hyper 212 Evo, and I might become one of those people... depending on how well this thing cools once I get it installed and start experimenting with OC-ing my Ryzen 5 3600X.
Can you all throw out some replacement fan recommendations? I've done a lot of research, but there are just... so many options.
Any go-to fan replacements you can point me toward?
If you have the money for it, noctua A12x25, it's the best fan on the market and it shoud server you rather well, it comes at the hefty pricetag of 29 bucks.
Otherwise the Noctua NF F12 is still good, it's $8 cheaper
Main PC [The Rig of Theseus]:
CPU: i5-8600K @ 5.0 GHz | GPU: GTX 1660 | RAM: 16 GB DDR4 3000 MHz | Case: Lian Li PC-O11 Dynamic | PSU: Corsair RM 650i | SSD: Corsair MP510 480 GB |  HDD: 2x 6 TB WD Red| Motherboard: Gigabyte Z390 Aorus Pro | OS: Windows 11 Pro for Workstations
Secondary PC [Why did I bother]:
CPU: AMD Athlon 3000G | GPU: Vega 3 iGPU | RAM: 8 GB DDR4 3000 MHz | Case: Corsair 88R | PSU: Corsair VS 650 | SSD: WD Green M.2 SATA 120 GB | Motherboard: MSI A320M-A PRO MAX | OS: Windows 11 Pro for Workstations
Server [Solution in search of a problem]:
Model: HP DL360e Gen8 | CPU: 1x Xeon E5-2430L v1 | RAM: 12 GB DDR3 1066 MHz | SSD: Kingston A400 120 GB | OS: VMware ESXi 7
Server 2 electric boogaloo [A waste of electricity]:
Model: intel NUC NUC5CPYH | CPU: Celeron N3050 | RAM: 2GB DDR3L 1600 MHz | SSD: Kingston UV400 120 GB | OS: Debian Bullseye
Laptop:
Model: ThinkBook 14 Gen 2 AMD | CPU: Ryzen 7 4700U | RAM: 16 GB DDR4 3200 MHz | OS: Windows 11 Pro
Photography:
Cameras:
Full Frame digital: Sony α7
APS-C digital: Sony α100
Medium Format Film: Kodak Junior SIX-20
35mm Film:
Lenses:
Sony SAL-1870 18-70mm ƒ/3.5-5.6
Sony SAL-75300 75-300mm ƒ/4.5-5.6
Meike MK-50mm ƒ/1.7
PSA: No, I didn't waste all that money on computers, (except the main one) my server cost $40, the intel NUC was my old PC (although then it had 8GB of ram, I gave the bigger stick of ram to a person who really needed it), my laptop is used and the second PC is really cheap.
I like tinkering with computers and have a personal hatred towards phones and everything they represent (I daily drive an iPhone 7, or a 6, depends on which one works that day)
The hyper212 uses a sleeve fan.  If it’s not set in the correct orientation it can wear out very quickly.  If it is put in the correct orientation it will still wear out slightly faster than a fan with a more expensive bearing.  hyper 212s are an old design so fans are going to wear out because they do that eventually.  Two bearing or modified rifle bearing will prevent orientation problems.  That Noctua mentioned is modified rifle bearing.
Side note:
One thing to remember with old style hyper212s with the plastic wings is while it looks like a clip it’s not. The wings are delicate and can break if you try to simply unclip it.  Unscrew the fan in place.
