so i need help overclocking my cpu im using overdrive considering im new to this. i have already oc to 4.3 but seem to be unstable and i just have a few questions. if u can help message me on Skype (garden2skill)
i have a:
cpu->amd fx6300
cooler-> corsair h80i
board-> gb 970a-d3p
psu-> thermaltake smart power 650w 80+bronze
gpu-> msi gtx 760 gaming
hdd1-> wd blue 1tb
ssd-> muskin (or however u spell it) 120gb
https://linustechtips.com/topic/121639-overclocking-help/
If you're getting an unstable overclock you can up your voltage a bit until it becomes stable.  Check your CPU's max voltage (google it) and make sure to not go over that.
I'd recommend manually overclocking straight from your mobo's bios rather than using AMD's overdrive as you can't adjust the voltage in that program causing overclocks to be potentially unstable.
Personal Rig v3: AMD Ryzen 7 2700X | Noctua NH-U14S | Gigabyte B450 Aorus Pro ITX | Zotac GTX 2070 8GB | 16GB G-Skill Trident DDR4 3200MHz | EVGA Supernova 750B | Phanteks Enthoo Evolv ITX
Peripherals: Sennheiser HD518 & Classic ModMic | Corsair K65 Luxe | Zowie EC2 | ASUS VG259QM  |  ASUS VG278E | Klipsch ProMedia 2.1
https://linustechtips.com/topic/121639-overclocking-help/#findComment-1619534
