i think you are missing a few parts mate, they should fit
G502 Lightspeed Review
PC:
i5-6400
GIGABYTE GA-H110M-DS2
CORSAIR VENGEANCE LPX 2X4 DDR4-2666MHz
ASUS ROG STRIX-GTX 1060-O6G
SEAGATE 2TB HDD
FUJISTU F300 240GB SSD
CORSAIR CX750M
Laptop:
Acer Nitro 5
i5 8300h
GTX 1050 4Gb
12 Gb RAM
128 Gb SSD
1 Tb HDD
Peripherals:
Keyboard:
Logitech G310 Atlas Dawn (Romer G)
Rexus Legionare MX5.1 (Content Browns)
Mice:
Logitech G602
Logitech G502 Lightspeed
Steelseries Rival 105
Logitech M330
Headset:
Logitech G430
Cooler Master MH 752
https://linustechtips.com/topic/1215948-help/#findComment-13769649
these should fit
PC specs:
Ryzen 9 3900X overclocked to 4.3-4.4 GHz
Corsair H100i platinum
32 GB Trident Z RGB 3200 MHz 14-14-14-34
RTX 2060
MSI MPG X570 Gaming Edge wifi
NZXT H510
Samsung 860 EVO 500GB
2 TB WD hard drive
Corsair RM 750 Watt
ASUS ROG PG248Q
Razer Ornata Chroma
Razer Firefly
Razer Deathadder 2013
Logitech G935 Wireless
https://linustechtips.com/topic/1215948-help/#findComment-13769651
the only two that fit togeth is the case and gpu. the gpu screws into back of case but after that you still don't have a computer
Favorite Threads: PSU Tier List
My Stuff n' Things
The Beast (My Rig)   |CPU: AMD Ryzen 7 7800X3D|  |Cooling: Noctus NHU12S Redux, 6x 120mm Noctua Redux|  |Motherboard:  Asus TUF B650-E WiFi|  |RAM: 4x8gb 6000 Corsair VENGEANCE RGB|  |Graphics Card: EVGA(RIP) GeForce RTX 3070TI FTW3|  |Power Supply: EVGA GT 850W|  |Case: Corsair 4000D Airflow Mid Tower Case(Black)|  |SSD: 1Tb SK Hynix Platinum P41 NVMe, 2Tb Inland Prime NVMe, 500gb Inland 2.5", 4tb WD Blue HDD|  |Monitor: MSI Optix MPG341QR 34" Ultrawide|  |Keyboard: Logitech G815|  |Mouse: Logitech G305|  |Audio Interface: FiiO K7 DAC/Amp|  |Headphones: Sennheiser HD6XX |Webcam: Logitech C920, Logitech C270|
My Network Rack  |Switch: Cisco Dell PowerConnect 5548P|  |Router: Unifi USG|  |Rack: 12U|  |Server: HP Z420|  |Services: Proxmox PVE, Wireguard, Pihole, NVR, NAS|
https://linustechtips.com/topic/1215948-help/#findComment-13769657
7 minutes ago, Olivier Hijlkema said:
I’m ordering the other parts later😂
yes but you gotta tell us what your ordering so we have context. it's like holding up a random bolt and asking "will this fit on my car?"
edit: for all we know it could be a ddr3 motherboard but we wouldn't be able to tell you the RAM won't work because we hav,t a clue which board you're getting
edit2: it's almost rhetorical
edit:3 would've been better to ask before ordering the parts
edit4: not trying to be a dick man. just trying to help you get the info you need in the most efficient manor
My Stuff n' Things
https://linustechtips.com/topic/1215948-help/#findComment-13769682
