Hi,
So i want to built a pc with the MSI B450 TOMAHAWK MAX  mobo in the be quiet 500dx. I know I wont be able to use the front usb type c port but are there any other compatibility issues i need to worry about?
Thanks,
Ryzen 7 7800X3D/32gb G.Skill TridentZ NEO 6000mhz/Gigabyte Aorus B650 elite AX V2/Asus Dual 4070Super OC
https://linustechtips.com/topic/1215840-case-compatible/
Nope, should be all good 😜
Quote
"Good things might come to those who wait, but not to those who wait too late" Bill Withers, 1981
My PC:
CPU: AMD Ryzen 7 2700x Motherboard: MSI X470 Gaming M7 AC  RAM16GB TeamGroup T-Force Delta RGB (2×8GB 3200MHz) GPU:AMD Radeon RX VEGA 64 MSI Air Boost OC Case: Lian Li Lancool 2 (With all accessories) Storage: Seagate Barracuda 510 512GB NVME M.2 SSD, 2× 5400RPM Seagate NAS 2TB HDDs PSU: GameMax RGB-850 850W Modular RGB 80+ Gold Display: Viotek GN32DB 32″ Curved Monitor – 144Hz 1440p WQHD VA with FreeSync Cooling: AMD Wraith Prism RGB Keyboard: Anne Pro 2 60% NKRO Bluetooth 4.0 Type-C RGB 61 Keys Mechanical Gaming Keyboard, Gateron Brown Switches Mouse: Logitech G402 Hyperion Fury Wired Gaming Mouse Sound: RAZER Kraken Gaming Headset Operating System: Windows 10 Pro Laptop: Clevo P641RE Gaming Laptop (14.1", i7-6700HQ, GTX 970M, 500GB NVME M.2, 16GB DDR4) Phone: Samsung Galaxy S9 128GB Coral Blue Earphones: Sennheiser Momentum True Wireless 2
https://linustechtips.com/topic/1215840-case-compatible/#findComment-13769097
nope.
Phone: Pixel 3a (Purple-ish).
Build Log:
https://linustechtips.com/topic/1215840-case-compatible/#findComment-13769107
1 minute ago, Ozzieh_man said:
irritated by 3 and 4 pin rgb conectors.
4 pin is 12v and 3 pin is 5v
They will not work together
A 5v will plug into a 5v and will not connect to a 12v and vise versa
Your motherboard does not have a 5v header
Build Log:
https://linustechtips.com/topic/1215840-case-compatible/#findComment-13769252
