Need help connecting chassis fans to motherboard
That is a RGB connector. Its also a 4 pin connector, which is usually a 12v RGB. That means a few things for you.
Your case is the Masterbox pro 5 RGB not the Masterbox pro 5 ARGB. the Masterbox pro 5 ARGB uses 5v ARGB connections.
Illl let you look at the cases on the website to see the difference, But the ARGB will have all the extras lighting options that you probably want out of an RGB setup. The RGB case Will colors just they will be more limited.
Either way your motherboard does not support any RGB.
You need to get a separate controller.
This controller will allow you the most control over your lighting and connect to your motherboard through a USB. Which looks like you have an extra one that you can use. Also the one i would recommend.
https://www.coolermaster.com/catalog/coolers/rgb-accessories/rgb-led-controller/
This controller is a basic inline controller and is vary limited in the color range that is select-able as well as in the modes that are available.
https://www.coolermaster.com/catalog/coolers/rgb-accessories/wired-rgb-controller-c10l/#image-Item7
If you decide to switch cases you'll still need a controller it will be a different one.
