Digital audio signal is interrupted by electrical interference coming from PC... even when powered off
Solved by rorythedawg,
Ok, it was the coax TV cable in the basement that was causing the ground loop, i guess that is grounded separately than the House plugs. With that unplugged I have no issue!
only figured this out due to this random thread I found when looking into ground loop isolators! https://forums.stevehoffman.tv/threads/do-ground-loop-transformers-isolators-degrade-sound-quality.461707/
Shout out to @HenrySalayne for figuring out it was a ground loop!
