Budget (including currency): $800 CAD
Country: Canada
Use Cases: This PC will be used for games such as Borderlands 3, Minecraft, Roblox, and Fortnite (overall, not very demanding games), played at high settings. It'll occasionally be used for video editing in Premiere as well as Photoshop.
Other details: Peripherals and monitor are NOT needed. This PC will be used with a 1080p 60Hz monitor. A 500GB SATA SSD and a 1TB HDD is ideal, but a 1TB SSD alone is also fine.
I think I've given most of the details, but let me know if you have any questions. Thanks.
CPU: Intel Core i7-950 Motherboard: Gigabyte GA-X58A-UD3R CPU Cooler: NZXT HAVIK 140 RAM: Corsair Dominator DDR3-1600 (1x2GB), Crucial DDR3-1600 (2x4GB), Crucial Ballistix Sport DDR3-1600 (1x4GB) GPU: ASUS GeForce GTX 770 DirectCU II 2GB SSD: Samsung 860 EVO 2.5" 1TB HDDs: WD Green 3.5" 1TB, WD Blue 3.5" 1TB PSU: Corsair AX860i & CableMod ModFlex Cables Case: Fractal Design Meshify C TG (White) Fans: 2x Dynamic X2 GP-12 Monitors: LG 24GL600F, Samsung S24D390 Keyboard: Logitech G710+ Mouse: Logitech G502 Proteus Spectrum Mouse Pad: Steelseries QcK Audio: Bose SoundSport In-Ear Headphones
https://linustechtips.com/topic/1215569-pc-build-for-a-friend/
Two sites I'd recommend.
https://www.systemrequirementslab.com/cyri -  to get the RECOMMENDED, not Minimum, spec's of the games wanting to be played
https://ca.pcpartpicker.com/  - to put a parts list together, based on the above.
**I frequently edit any posts you may quote; please check for anything I 'may' have amended.**
Current PC spec. in my profile.
Can I realistically call myself a gamer, if I only play ONE, twenty year old game...?
Did you test boot it, before you built in into the case?
WHY NOT...?!
https://linustechtips.com/topic/1215569-pc-build-for-a-friend/#findComment-13767093
Not to offend you or anything but I know what PCPP is.
It's just that I've lost touch with PCs a bit and I'm not too familar with the newest CPUs, motherboards, and graphics cards.
Thanks anyways.
https://linustechtips.com/topic/1215569-pc-build-for-a-friend/#findComment-13767123
Country: Canada
Its not a great amount of money, but you can get a decent entry level system. Heres my suggestions:
Few things to note:
-I don't know CAD pricing but a used RX580 may be a better option if its cheaper. You can then spend a bit more to get a better motherboard (something like the asrock pro4) and maybe a better case.
-The case doesn't have great airflow from what i hear, so if you can find better that's great.
-PSU could be better, but it will work and its quite a price jump to get something better
Hope this helps :)
Edit: If you want to do video editing then something like a 1600AF (12nm) would be good if the price is right. If not maybe a 2600 or at least a 3300X (3300X would be the best in games but 2 fewer cores)
PC
Ryzen 5 2600 Stock
Sapphire Nitro+ Special Edition Radeon RX580 8GB (Would Recommend)
Gigabyte B450M DS3H (Don't recommend)
Hyper 212 RGB Black Edition
Corsair Vengeance LPX 2x8GB DDR4 3000MHz CL15
Phanteks P300 (Would Recommend)
Kingston A400 240GB SSD
Seagate BarraCuda 1TB HDD
Corsair CX550M 550W  80+ Bronze
Deepcool FH-10 Fan Hub
3x BeQuiet Pure Wings 2
https://uk.pcpartpicker.com/user/marmour/saved/QTY3ZL
Peripherals
LG 24MK400H
Logitech G413 Carbon
Logitech G305 (AAA Adaptor - 10g reduction) (Would recommend)
Logitech Z150
HyperX Cloud II (Would recommend)
Moto G5 Plus (Webcam)
Phone
Pixel 3A XL (Would recommend)
*Useful Link* PSU Tier List: https://linustechtips.com/main/topic/1116640-psucultists-psu-tier-list/
https://linustechtips.com/topic/1215569-pc-build-for-a-friend/#findComment-13767145
PCPartPicker Part List
CPU: AMD Ryzen 5 2600 3.4 GHz 6-Core Processor  ($195.75 @ shopRBC)
Motherboard: ASRock B450M Pro4-F Micro ATX AM4 Motherboard  ($118.05 @ Vuugo)
Memory: Team T-FORCE VULCAN Z 16 GB (2 x 8 GB) DDR4-3200 CL16 Memory  ($83.99 @ Newegg Canada)
Storage: TCSunBow X3 480 GB 2.5" Solid State Drive  ($53.99 @ Newegg Canada Marketplace)
Video Card: MSI Radeon RX 580 8 GB ARMOR OC Video Card  ($224.99 @ Memory Express)
Case: Rosewill FBM-X1 MicroATX Mini Tower Case  ($49.99 @ Newegg Canada)
Power Supply: Gigabyte P-B 650 W 80+ Bronze Certified ATX Power Supply  ($79.99 @ Memory Express)
Total: $806.75
Generated by PCPartPicker 2020-06-28 23:46 EDT-0400
https://linustechtips.com/topic/1215569-pc-build-for-a-friend/#findComment-13767706
